2008 Polo GTI Boot Latch Issue
  • 2008 Polo GTI Boot Latch Issue
    EDIT: I'm an idiot, and didn't realise there was a key press sequence, please ignore
    Hi All,
    Wondering if anyone has come across this particular issue before. Did some searching, couldn't find much, thought I'd ping the brains trust.
    So I just picked up a 2008 Polo GTI. Cool little car, great fun.
    But... has a weird boot latch issue. It won't currently open if the latch is in the fully closed position (2 clicks of the latch). However, if you just catch it on the first click (boot shut, but not fully latched), the actuator works perfectly fine, as does the switch, and the boot opens.
    I'm thinking that there is a second sensor is the actual latch mechanism itself that appears to be detecting the first click and allowing the boot to open, but not the second.
    Anyone else come across this issue?
    Cheers.
    Only time I've had this issue, is when I don't code the selective locking off.
    VCDS -> 46. Cent Convenience -> Coding -> Change 00016 to 00017 and save.
    One press unlocks the entire car. And it stays unlocked until you lock it/if you don't open anything. It will self lock.
    The latch has two positions, might need to adjust the bump stops on the tailgate
    AND OR
    Latch-actuator so it doesn't get stuck half way.
    Hope this helps a bit
      Had this problem a few years back, turned out it was a faulty tailgate switch..
      Pop the backing off your boot liner and replace this switch, problem solved
      Volkswagen Polo 9N Tailgate Micro Switch 1T0962103 NEW GENUINE | eBay
      Polo Boot refuses to open!
      2016 Golf R, APR Stage 1
      2010 Polo GTI 9n3, 4 Program APR Tune, PD160, White line front and rear sway bar
