Been meaning to get something up on this for a while. I wanted to actually finish it first but now figure why not live dangerously and do a blog on the conversion as its actually happening (or failing?).
So what I'm doing here is sorting out a turbo conversion from the stock K03s to an IHI RFH5 from a Golf Mk6 Gti. Here's a little rundown of this turbo and its relatives:
- Golf Mk5 Gti, EA113 engine = Borg Warner K03
- Golf Mk5 Golf Pirelli & Golf Mk6 'R', EA113 engine = Borg Warner K04-064
- Golf Mk6 Gti, EA888 Gen1 engine = IHI RHF5
So from what I understand IHI are the parent company of Borg Warner or at least the American arm of it. From this turbo onward it seems VW went over to running IHI's after their longstanding relationship with BW turbos. The IHI turbo in the newer Mk6 Golf Gti engine is a very close reproduction of the BW K03 in the Mk5 Golf Gti. Ive had mine side by side with the BW and they are only subtly different outwardly. eg wastegate actuators. The compressor wheels are virtually the same but the later IHI has fewer blades but a bigger hot side wheel so may be better up top?. But put simply the IHI RHF5 in the Mk6 Gti is often referred to as "K03" despite very definitely not being a BW turbo. Its just that the name fits since its big brother the 'R' still carried a BW K04.
So what all these turbos have in common despite being on earlier EA113 engines or the later EA888 Gen 1 and 2 engines is that they have the same exhaust manifold designs in that they outwardly appear to be 4-1 long runner designs fit to the head by sitting in a 'rail' on the underside of the exhaust manifold and then pivoting up to meet studs on the top side.
Their manifolds are also integral castings with the turbo hotside which gets you away from the crappy exhaust manifold to turbo connection gasket leaks that especially K03s's suffer from and the manifolds themselves look to be a very free flowing design in comparison to the choked down 1.8T 20V K03/K04 designs.
And what makes this conversion possible? Our 1.8T 20V has the exact same port sizes and port spacings as both of the later engines mentioned above, so with an adapter plate between the head and the exhaust manifold of the turbo, they fit on the 1.8T 20V.
What got me interested in this conversion was first seeing guys in the UK doing a similar conversion with the larger BW K04-064 in Audi A3's, Golf Mk4's etc. I'm sure people will be wondering why I would do the conversion with the Mk6 Gti turbo rather than the K04-064, well there were a few reasons:
1. the BW K03, IHI 'K03' and BW K04-064 are all very similar dimensions. The smaller two of the trio actually carry very similarly sized housings meaning that a Mk6 Gti turbo that fits now, can easily be plug n played with a bigger K04-064 down the track.
2. I don't have rods yet! I actually have all the bits together for a proper rebuild of my spare engine. I could have waited to rebuild that and then swing it all in with a K04-064 attached but that would realistically have been a good year+ away. Instead I figured I'd get this turbo up and running, the car will still be a good step quicker than what I've had but shouldn't bend the stock rods in my existing engine if we're careful with the tune. But yeah the eye is definitely on the K04-064 out of the Golf R in the long term.
3. There's a fair bit involved in the conversion so I wanted to get it all squared away and not be stuffing around trying to get things to work on a new rebuilt engine later. Ive seen rebuild engines hit brick walls with tunes, hardware problems and development etc, in and out of work shops, way too much idling and bore glazing when what they should be doing is turning the key and getting quality run in kays on the motor. I wanted all the little things eg intercooler pipework, MAF sizing/placement, boost solenoid compatibility, whether the thing will even fit in the little Polo engine bay! etc, to be sorted before a rebuilt engine goes in.
4. ha ha and I was basically gifted a nearly brand new Mk 6 Gti turbo which gave me a decent bump in that direction!
and as for why this turbo in comparison to a K04-022/023 from an Audi S3 Mk1:
1. they have horrible OEM exhaust manifolds, maybe even worse looking than the Mk golf/Polo Gti.
2. The stock manis have tiny little collectors at the exhaust to turbo connection that incinerate gaskets and come loose no matter what you do.
3. I've never liked the look of the aftermarket K04-022 manis. runners directly facing each other at the collector, no gas guides down into the turbo etc
4. Id seen pretty reputable people in the UK saying that the smaller TFSI turbos outperform K04-022/023's because they can do everything the other turbo does on less boost, with more timing advance and lower EGT's. Mine is a turbo specced by the factory for a 2.0L engine so constitutes a performance and generational upgrade all at once.
So there you go. After all the work so far It may not even fit into the Polo engine bay. The only other people I could see who had done this conversion in a Polo were in Greece. They are left hand drive with no brake booster/master cylinder in the way, so it could be that with a RHD Polo that i'll run into some serious dramas. But what the hey, I'll try!
r0AAOSwqcJbq8oH
