Exhaust went in today. The down pipe section of the K03s/K04-001 dump was cut off and in its place a dump off the TFSI turbo was made up. From what I can gather the flange is the same between the earlier BorgWarner Mk5 K03 version of this turbo, so if I have to change to that iteration then it'll fit too. The K04-064 from the Mk5 Pirelli and Mk6 'R' has the same flange but I'm not certain its in the exact same spot. Either way I'm pretty sure 3 turbos will work on this dump/flange. So the conversion is complete.....no going back!
The orientation on these pics is a bit whack but you get the gist. So it turned out that the 90 straight off the flange did work. Its mouth had already been opened up. It just had to be cut closer to the bend to make it eliptical in the vertical plane and then the sides stretched wider. Its ever so slightly angled towards the drivers foot and then all it needed was a small little 45 degree to turn it under the car. I got it flanged too. It might be fine on a hoist to twist and turn 2 meters of one piece dump pipe out of the car but not when you are lying on your back on stands in your garage or at the track. The flanges allow me to drop the centre section straight out the bottom and then removing the down pipe is just some very accessible nuts.
I;ll probably drive it tomorrow on the stock MAF and old turbo tune just on the spring and the next mission will be upgrading the TIP for the bigger MAF and getting the juicier base map into it.
