Question concerning cam cover gasket renewal. Other than putting a little dab of sealant at each of the four corners before putting the gasket down, does the gasket fit as is onto the mounting grooves alone, without any other sealant? I've seen loctite hi tack gasket sealant spray being used to treat the gaskets before they are laid down. Just curious what others have done.
Also re the half moon and its gasket (associated with the cam tensioner) , I've been told that its good to do those at the same time. Mine isn't leaking from there - is it likely to spring a leak if its not already by being disturbed when the cam cover is lifted or is it a best practice type of deal. I ask because it looks like a hell of a lot more work to add that into the equation of what otherwise looks like a very straightforward cover gasket job. Is it possible to do those without lifting the inlet cam by just releasing the tensioner bolts and sliding in the half moon and its gasket or do you have to go the whole hog and lift the inlet cam, release the tensioner with the special tool and lift the tensioner assembly entirely for proper access?
thanks
sam
thanks
sam
