I read somewhere that you should not use the hand brake when parking the car after a hard brake use as it could cause the rotors to warp
Front rotor replacement issues. 8/2010 77TSI
It's usually the front ones that warp, not many manufacturers have parking brake acting on the front wheels.Originally posted by maxrob200 View PostI read somewhere that you should not use the hand brake when parking the car after a hard brake use as it could cause the rotors to warp
Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
You are correct, though the chances of getting them hot enough on the street then stopping immediately is unlikely. The issue is pad compound transfer to rotors. I've had that issue after track sessions resulting in a clear pad imprint to the rear rotor. For street driving, it's much less unlikely unless it's a mountain run or something.Originally posted by maxrob200 View PostI read somewhere that you should not use the hand brake when parking the car after a hard brake use as it could cause the rotors to warpTrack Car: 06 Polo GTI Red Devil mkII
Daily: 2010 VW Jetta Highline
