DSG reving high when keeping speed going down hill. Normal?
Wondering if this is normal: when I drive the new Polo and I come to a steep hill, when using the break to keep the (60km/h) speed limit, the gearbox kicks down to 3rd gear and revs over 3000rpm. Before I put my foot in the break to keep speed it's in gear 6 or 7 and then kicks down to 3.
Normal?
VW Tiguan 2018 162TSI Highline
VW Polo 2015 81TSI Comfortline
Try not releasing the brake pedal completely while going downhill, just gently modulate. Certainly it downshifts the second time I touch the pedal without using the gas pedal in between. Our 2004 BMW does the same thing and it can be annoying when you want to coast a bit. I have to briefly tap the gas to get it to upshift.
Or use tiptronic to select the hear you want. The manual recommends 3rd gear for steep declines and general advice is not to ride brakes for an extended period of time (ie down a mountain).
Normal?
Completely normal. My polo gti did it my new golf gti does it....my mk5 tdi didn't. So newer dsg engine combos are programmed to use engine braking as much as possible i think.
I just compared it to the S-Tronic Audi. The Audi on the same hill uses the actual brake more and stays in around 5th gear. The Polo uses the gears (3rd) to brake but it won't keep speed as well as the Audi. The Polo will continue to accelerate on a very steep hill where as the Audi holds speed.
According to the 2014 owner's manual it's also supposed to coast (both clutches open) when you are off the gas but before you start braking. I can't say I seen this effect on the tach, it seems to just stay in 7th.
I thought you were braking when the 'boxes downshift
Resident grumpy old fart VW - Metallic Paint, Radial Tyres, Laminated Windscreen, Electric Windows, VW Alloy Wheels, Variable Geometry Exhaust Driven Supercharger, Direct Unit Fuel Injection, Adiabatic Ignition, MacPherson Struts front, Torsion Beam rear, Coil Springs, Hydraulic Dampers, Front Anti-Roll Bar, Disc Brakes, Bosch ECU, ABS
