Polo 6R Boot Light issue
    possible... but ive only ever seen the rear washer leak causing that issue....
    BRISBANE / GOLD COAST
      Ok just a thought.
      Alex Aescht
      MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
      MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
        Hi from 2024
        Originally posted by alexaescht View Post
        Thanks I'll try that later and report back.
        Would putting the car through a touch less car wash maybe get water in places it shouldn't be?
        Hi Alexa, did you ever solve this problem and get the boot light working? If so how? I have the same issue on my polo gti. Hopefully you still see this message considering how long its been. Cheers
          @Polo gti 6r: Hi.
          I'm also not sure if Alex is still around !! However, with the hope that I'm not stealing his thunder - this is my very cut-down version of how the "boot light" is wired (I'm assuming that your car is a hatch version):
          If you are not familiar with VW's wiring notation - notice T5h /2 on my diagram. This means:
          • T5 = is a connector with a Total of 5 x pin positions
          • h = a simple designation that identifies this 5 x pin connector from multiple other 5 x pin connectors on the car
          • /2 = pin #2 on the connector
          So, the story that the wiring diagram tells - is:
          1. The supply for the boot-lid light (W3) comes from J519 (which is the module for lots of "convenience" facilities on the car). Notice that there is NO circuit fuse - J519 auto protects this circiut
          2. The same power supply for W3 also feeds W6
          Because you haven't said that the glove compartment light (W6) is also faulty - the fault is probably NOT in the J519 wire
          There are 4 x connections that could cause W3 to be faulty:
          1. T2 = the connectors for the boot light
          2. T5c
          3. T5h
          4. T3 = the connections in the boot lid switch, or the switch in F5, itself
          According to the Polo repair manual, it's NOT possible to renew the switch in F5 without replacing the entire boot- lid mechanism.
          So, my suggestion = grab a multi-meter and start checking the connectors above!!
          Don
            You can buy a whole new Boot release on EBAY for about $30 and is identical to a factory part Difference is about $100 and fixed a similar problem in our Polo . You can also buy a new LED light on Ali Express for under $20 which gives much more light
            For VW Golf MK5 MK6 Rear Tailgate Trunk Boot Lock Latch Lid Actuator Brand New | eBay
