Polo 6R Boot Light issue
  • Polo 6R Boot Light issue
    hi guys
    my boot light stopped working properly long time ago, it started with a long delay before it turned on and now its completely stop working.
    can anyone point me out the problems?
    cheers
    2010 6R 77TSI, Bilstein PSS14 CoilOver Kit, Front GTI Brake conversion
    Apart from the normal "take it to a dealer" what you described sounds a bit like the switch is the issue.
    Mk8 Golf GTI
      Mine does exactly the same thing, with a delay between opening the boot and the light turning on.
      Have you noticed a change in the sound/behaviour of the boot release mechanism by any chance?
      Alex Aescht
      MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
      MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
        have you actually checked the bulb? if the bulb is ok its more than likely the boot latch micro switch playing up. when you open the boot does it display the door open symbol on the dash panel?? ....VDUB....
        BRISBANE / GOLD COAST
          It will be an open circuit some where in the boot, best to take it to stealership. Had the same problem with mine
          MY11 Polo Trendline, Candy white
          RCD510, R badge, AP X coilovers, 17" Ariettas in gloss black, Rear muffler delete, GTI pedal covers, gloss back emblems
          soon to come, Front lip & Fat bottom steering wheel
            In mine, the bulb is fine and no open door/boot light comes on the dash.
            Alex Aescht
              then it will need a new boot latch if the wiring is ok which it 99%of the time is.... not a hard job....VDUB...
                Ok thanks
                Alex Aescht
                  my boot light comes on the dash
                    bulb ok? holder ok? connection plugged in?.....
                      everything appears ok, the bulb, holder and plug.
                        Have you actually got 12v at the plug?,
                          I just had a closer look at mine and the bulb and holder are fine, but there is no voltage at the plug at all, except occasionally when it decides to work.
                          So I think it's a switch or something that's failed.
                          Alex Aescht
                            sometimes the rear washer jet leaks into the boot latch and micro switch and causes issues... press and hold rear washer jet on for 10 seconds then open the tailgate and see if any water comes from the latch area from around the interior trim..
                              Thanks I'll try that later and report back.
                              Would putting the car through a touch less car wash maybe get water in places it shouldn't be?
                              Alex Aescht
