quick question does anyone else's front suspension make a slight gas noise over sharp bumps, is this normal?
New Polo problems - Register
Originally posted by kkierann View Postquick question does anyone else's front suspension make a slight gas noise over sharp bumps, is this normal?Alex Aescht
MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
I am having a small problem with my 2 month old Polo.
In lower gears, if Engine RPM goes above 2000, on pressing clutch, I feel pulsations/vibrations. One day while driving, there was a ghrrrr/khhhhrrr sound from below and this issue exists since then.
Secondly, car jerks slightly while taking off from start. Is it a clutch problem?
My clutch never slips and my FE is very good.
Driving about today, the lightbulb (!) warning light light lit up. Got out, looked for the blown bulb, couldn't find anything. Switched the car off, back on again, no warning light. Anyone had this?
Current Ride: Golf GTI Mk7 MY2014|DSG|Carbon Steel
Previous Ride: Polo GTI MY2012|DSG|RNS510|Shadow Blue|Lenso GF7 18” rims
Instagram: @lemonskin
Originally posted by Lemonskin View PostDriving about today, the lightbulb (!) warning light light lit up. Got out, looked for the blown bulb, couldn't find anything. Switched the car off, back on again, no warning light. Anyone had this?
Originally posted by dissapolo View PostThis happens to me all the time. Occasionally its the left hand indicator but rebooting the car sorts the issue but most of the time its nothing.
Polo GTI - 5 door - Candy White, Xenons, Comfort Package, Audio Upgrade, Bluetooth, Parking Sensors and Tint
Not a problem just a question... Is it bad for the DSG to put it into neutral while driving? I've taken to shifting it into neutral when I come to a large downhill run because I don't like the way the DSG shifts down to brake using the engine.
I guess I coudl always just shift up manually but I just find putting it in neutral is easier.
Originally posted by Lemonskin View PostIs it bad for the DSG to put it into neutral while driving? I've taken to shifting it into neutral when I come to a large downhill run because I don't like the way the DSG shifts down to brake using the engine.
The engine braking is actually a much better way for the car to hold its speed downhill as
1) you don't use any fuel when in gear
2) you aren't riding the brakes downhill and so they don't overheat/wear prematurelyMY13 Polo GTI, also Candy White with pleather
Originally posted by Lemonskin View PostNot a problem just a question... Is it bad for the DSG to put it into neutral while driving? I've taken to shifting it into neutral when I come to a large downhill run because I don't like the way the DSG shifts down to brake using the engine.
Have had it happen and its not a nice feeling2021 Kamiq LE 110 , Moon White, BV cameras F & B
Originally posted by anglo_dude View PostYes it is bad for the gearbox to do this. The reason is that the gearbox does not have any oil circulating through the gearbox unless the car is in gear, and so the box can overheat if it is in neutral for a long time.Alex Aescht
