EPC problem in 4th gear
  • EPC problem in 4th gear
    If I am parked with motor running and Clutch depressed
    Select 1st Gear - Engine idles at 650rpm
    Select 2nd Gear - Engine idles at 650rpm
    Select 3rd Gear - Engine idles at 650rpm
    Select 4th Gear - EPC light comes on, engine runs roughly as fuel (or sparks or both) turns ON and OFF*
    Stop/Start system will be in Engine Not Running error. This typically doesn't go away for ten minutes
    You really don't want to have low throttle in 4th gear whilst driving because this gets really ugly
    So I generally just use First, Second, Third and Fifth Gears
    I am guessing it may only be OFF for say 100 ms
    It could also be noted that I often get the Stop/Start error "Engine not running" in normal driving even if I don't select 4th gear
    My Local Mechanic found the problem the last time I got my car serviced. Apparently when the manual gear selector was in 4th gear, there was a metal rod rubbing against a wiring harness. With time, this had completely worn through the insulation of a purple wire and was earthing out the wire
    Wiring has been taped up, and wiring harness has been cable tied out of the way so that it doesn’t contact the manual gear selector problem solved
