New Passat 206TSI R-Line
  • Originally posted by Buffy View Post
    Hi Wynnston,
    How is driving the car without TCS? I am a bit worried about having that off.
    DR074 did you do the hack? Has it disabled your TCS?
    Thx
    Working normal after tuning the coding to Audi in Engine Section by OBDELEVEN
    Nothing noticed with TC
      Hi Wynnston,
      DR074 did you do the hack? Has it disabled your TCS? Is it a simple 5 minute job just to plug in and change the code to Audi?
      Thx
      Yep, did the Audi change, throttle response is better, noticeable difference. It didn't disable my TCS. I think what Wynnston is saying is, that because of the increase in throttle response, its easier to brake traction (wheel spin). The TCS doesn't take the Audi change into consideration and doesn't work as he expected. Wynnston, correct me if i'm wrong.
      Personally, it works for me.
      Yeah, 5 min job.
      Mine - Mustang GT MY20 - Carbonised Grey - "Nicky"
      Hers - T-Roc 140 TSI Sport MY21 - Reveena Blue - "Rocky"
      Previous - Passat 206TSI MY17 - Night Blue
        Hi Wynnston,
        Thx
        It doesn't disable TCS, nor does it throw any faults on the car. I am just saying that the TCS system goes a little funny (yes I know, not scientific). I'm guessing its either because the Haldex isn't keeping up or that it's just not calibrated to the conditions (not as reactive as it should be). We got a spurt of wet days over here and I had a chance to run the car down the drag strip last wednesday (it wasn't wet that afternoon). The XDS adjustment might be the solution, but I'm a little apprehensive to go that far.
        While I still have a lot of tread on my tyres, it is worth noting that they have 36k kms on them now, so slight changes in tyre wear might make it more noticeable.
        MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
        MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
        • I guess the good thing about the car, is that no matter your driving style or what sort of driving you are doing (Track, Drag strip, Highway or City driving), its pretty adjustable and gains in performance are obtainable.
          • Thanks for the info guys.
            Wynnston what times did you do for the 1/4 with the Audi hack?
              12.7 (Link Here)
              A lot of failed runs with LC with the Audi mode on, this was the best I could get.
              • Can someone point me to a thread where there is a beginners guide to coding. I'm mainly looking for equipment and how the pricing structure works. I did a few searches but can't seem to find a guide.
                MY18 206 TSI WAGON
                • There are a couple of ways of coding, VCP, VCDS and OBDEleven that I know of. I'm sure there are others.
                  I've been using OBDEleven and have used the below from DV52
                  OBDEleven - The new kid on the block!
                  Also Home | OBDeleven may help as well.
                  I know nothing about VCP, so don't have any links.
                  RossTech have a good website that will help with the VCDS
                  Ross-Tech: Home
                  hope this helps
                    Hi all,
                    Has anyone here done a tune or chip to get rid of the lag in first gear. I test drove the new 206 R, but found the sluggishness from a standing start annoying coming from the V6. In fact after the test drive got back in mine and decided not to upgrade.
                    I understand turbo lag V NA, but with tuning can the sluggishness be removed?
                    Many thanks in advance.
                    APR Sage 1 tune really improves this with huge gains in kW and Tq.
                    Recommended.
                    Bockey
                    2023 Tiguan R Driver
                    • Originally posted by DR074 View Post
                      Ross-Tech: Home
                      hope this helps
                      That's awesome, thank you
                      MY18 206 TSI WAGON
                      • Is the 206 sedan still available in Australia? The VW website shows the ‘build your own’ only in the wagon model, not the sedan
                        • Originally posted by bigW View Post
                          Remembering someone talked about it before.
                          No sedan 206 anymore.
                          • R line 206 sedan is still listed in the ‘models’ page. Not being able to use the build page could be an IT issue, or it could mean they haven’t decided on specs moving forward past current stock on hand.
                            • Just confirmed via the dealer this morning- VW have canned all diesels, and they are still making the 206 wagons and not the sedans (being ‘replaced’ by the Arteon).
                              Dealer reckons the Passat 206 sedan will hold its value anyway as they are specced in a similar way to the Arteon (apart from the polarising looks and the 7 not 6 speed) and about $10k cheaper
                              • Does that coincide with any MY changes that the dealer would know of?
                                MY14 MK VII GTI | Pure White | Manual | Bi-Xenons (his)
                                MY19 B8 Passat 206TSI wagon | Manganese Grey (hers)
