ABS Sensor
  • ABS Sensor
    I had a bunch of errors come up on dash recently. ABS, ESC system, tyre pressure system. Also cruise control and hill assist and park pilot don't work. I have had a scan done and it seems to be the left rear ABS sensor. Is this something i can replace myself. I have enough mechanical skills to do minor things and this looks pretty minor. I have seen i can buy a bosch ABS sensor from Run Auto Parts for about $50. Do you think thats adequate ? It says its compatible with my car.
    Passat Alltrack MY16
    Very common fault and yes its 1x bolt and 1x electrical plug to replace the sensor. Just make sure you get either a genuine sensor or a good quality aftermarket alternative - avoid junk Chinese ebay/Aliexpress stuff.
    This 'should' be the correct part, but I would visually compare to your current sensor and also see if the part number matches up with one of these:
    7L0927807A, 7L0927807B, WHT003857A
    B9 Audi SQ5
      Thank you !
