Hey guys!
Got a 2016 Passat Alltrack with demons.
About 2 weeks ago my car started throwing every electrical system error under the sun. It would do it on ignition power, and only do it 1 in every 30-50 starts.
Each time it happened, Id turn the ignition off, attempt to restart the car and it'd start, run and drive no problem.
It was previously only doing this at ignition at startup, however today it did it mid drive and switched off in the middle of a highway.
Ive got a few small elec issues Im aware of (front air distribution servo, windshield washer pump motor), but this is a mess, and no shop is available to diagnose it for nearly a month.
Some errors I keep seeing in my logs are "Databus message missing/implausible/error value received" (across all literally every control unit), and "Lost Communication with ECM/PCM", which suggests to me either canbus or ECU?
Any ideas?
You can see the full error log at:
Dropbox
TIA!
http://cloud.tapatalk.com/s/678f752e...BD11%20Log.pdf
Sent from my Pixel 5 using Tapatalk
Any ideas?
Dropbox
TIA!
