206tsi R-line - Power loss and misfire
  • 206tsi R-line - Power loss and misfire
    Hey there brains trust. Hoping for some advice on a few fault codes that have popped up.
    Car is 2017 206 r-line wagon. APR Stage 1 and DSG tune, ODO about 100k.
    When accelerating relatively quickly (more than say 50%), I can feel power surges which throw an error on the dash saying “EPC”. It activates some sort of limp mode with very low power. When I stop, the car is idling rough, and if you rev engine to 1.5k rpm there is a very noticeable engine shudder - one cylinder not firing and out of balance maybe?
    If I turn the car off and back on - all is fine and drives normal (if you don’t accelerate quickly). I drove for 4 hours like this today with no issue.
    I have read the below codes using a cheap OBD2 reader:
    P0304 - cylinder 4 misfire detected
    P0302 - cylinder 2 misfire detected
    P0300 - random/multiple cylinder misfire detected
    B2AAA - body
    After clearing codes - everything is normal but I can not rev past 5k rpm while stationary due to a rev limiter.
    I plan to swap over coil packs 2&4 with 1&3 to see if they are the problem. Plug were replaced 30k ago.
    Any other ideas what this might be?
    Thanks in advanced - Jeremy.
    Sounds like your typical dead/dying ignition coil symptoms. If the misfire moves to the other cylinders when you change them over then you can be pretty certain this is the issue.
    New aftermarket ignition coils can be purchased if you want something a little bit different to the stock ones. I had APR coils on my Golf GTI a few years ago, but 034 Motorsports and Racingline also offer them now. They are all available in various colours too.
    034 - High Output Ignition Coils (x4) - VW Golf MK7 GTI/R & Audi S3/TT/TTS– VAGPARTS Australia
    RACINGLINE HIGHER OUTPUT IGNITION COIL / MQB EVO / MQB 2.0TSI, 1.8TSI, 2.5TFSI [VWR900000] - Harding Performance
    APR Ignition Coil Pack Red SINGLE - Audi A3, S3, RS3 8V (Facelift) /VW Golf GTi, R Mk7-7.5 MS100192
    B9 Audi SQ5
      I have the 034 ones - they are red, so they go faster. They also have heatsinks that probably don't do anything, but sound like a 'cool' idea.
      2018 Arteon R-Line - Black, Sunroof, Dynaudio, 20" Wheels, RacingLine: Stage 2 ECU+DSG|380mm BBK|Intercooler+Hoses|Oil Cooler|R600 Intake|Adjustable Front Droplinks|Dogbone Insert|Subframe Brace+Alignment Kit|Propshaft Alignment Kit, Milltek: Zirotec Downpipe, Harding: Front+Rear Sway Bars|Rear Droplinks, Other: OSRAM Dynamic Indicators, EvcX Throttle Controller, 034 (RED) Coil Packs, Various Carbon Bits
