DSG Chirping Noise 2nd to 3rd and 4th to 5th?
  • DSG Chirping Noise 2nd to 3rd and 4th to 5th?
    Dear All,
    I have a 2015 Passat B8 and for a while have noticed a quiet whistling sound when in D or S moving from 2nd to 3rd and 4th to 5th.
    from another forum I've deduced this might be when changing/actuating between shafts as the gearboxes are arranged 1st ,3rd,5th, 7th and then 2nd,4th,6th
    Hence this slipping noise happens when shifting from the second gearbox (2nd and 4th up to 3rd and 5th)
    Has anyone heard of this before and can it be fixed?
    Thanks!
    Originally posted by olliek57 View Post
    Dear All,
    Thanks!
    Is posssibly clutch slip as there is only one gearbox and two clutches do the swapping. One does the odd gears and the other does the evens. So they swap between each other as the box changes up or down
      Here is all about the DSG gearbox
      https://drive.google.com/file/d/1K2w...ew?usp=sharing
