Battery charger for Stop Start battery
  • Battery charger for Stop Start battery
    Because I dont use the Wagon often the battery is going a bit flat between uses. HAd car serviced today and Service manager suggested I use a trickle charger on it between uses.
    Is of course an AGM battery and I was thinking along the lines of a Cetek 5 or 7 amp charger.
    They are a good brand and I have used one when 4Wding
    Suggestions please but I wont be buying any $50 cheapy
    Ive got the 5amp (MXS5.0) CTEK charger - works great and is nice and compact.
      Originally posted by Lucas_R View Post
      Ive got the 5amp CTEK charger - works great and is nice and compact.
      Same here, highly recommended
      CTEK will happily stay plugged in the whole time if you want or you can just charge it up once a month (or as needed).
        I use CETEK 7.0
        2018 BMW 125i M Sport |AlpineWhite|719M JetBlack|BlackLeather |ComfortPackage|Sunroof|WirelessCharging
        2010 MY10 R36 Wagon | Biscay Blue | Power Tailgate | RNS510 | MDI | RVC | 51,000 km |Garage Open Button | Dead Pedal Mod | OE Fit DRL | VCDS | Sprint Booster | H&R Rear Sway Bar | Alcantara Steering Wheel | Dual Reverse Light | 19" Bentley Wheels (BBS Forged Split) | Michelin PS 4S
        2005 MY05 AH Astra HatchBlack | Facelifted SRi Looking | OpeliZed | Whiteline RSB | Eibach ProKit
          Originally posted by Passat R36 View Post
          I use CETEK 7.0
          Yeah had one of them when I had a Cruiser and a van with 4 700CCA batteries between them but dont need that much or that many $$$ to trickle charge the Passat I dont think
          Thanks any way. Will go for 5.0 at $118
          Will connect the rings and then can take it out when necessary
            Anyone tried the test and charge MSX 5.0 Is it worth the extra $50
              If you mean the MXS 5.0, I have one and can recommended it. It has an AGM and recondition function. I hook it up to the Passat and all my other cars once a month to top them up and check on their condition.
                [QUOTE=Amalgam;1192129]If you mean the MXS 5.0, I have one and can recommended it. It has an AGM and recondition function. I hook it up to the Passat and all my other cars once a month to top them up and check on their condition.
                https://www.ctek.com/Archive/Product...S%205.0_EN.pdf[/QUOTE Was referring to this one which has a couple of maybe useful functions and was wondering if it is worth the extra money. I decided it wasnt and bought the cheaper one
                FREE SHIP- CTEK Battery Charger MXS5.0 TEST & CHARGE - CTEK Products - Power Generation
                  Thanks for info I ended up buying a MXS 7.0 from Autobarn for $159 sale price Does the job perfectly.
                  The online outfit stuffed me around so I cancelled it
                    Further to this thread I had a flat battery today (Left reading lights on) and rang VW for cost of replacement $471.49 and $77 to fit and calibrate car.
                    Rang Battery World who were dearer and also told me I have the wrong Ctek charger.
                    Said they make a specific charger for Stop Start batteries. Have emailed Ctek to check if thats correct as havent seen them offered for sale in AUS.
                    Not having a good day LOL
                      AGM Battery with MXS 7.0 AGM Charging Mode?
                        Already got that and they say its the wrong one
                          I ve been using that for 2 years without any issues.
                            Well now there is this one and the guy at Battery World says its the proper one to use so will repost when I hear from Ctek
                            CTEK CT5 START/STOP
                              is start/stop battery a new type battery?
