Hi All,
I've replaced the failing park brake control module with a new revision 3AA907801E module.
I've coded the module correctly and it is functioning (park brake is correctly engaging and disengaging with the button or automatically as expected).
However I've also upset the associated systems (as expected) and not sure how to correct them...
I understand I need to correct the ABS module fault codes to get to the next step. However when I go into the ABS module and try to select the basic settings, to for example try and do the G251 adaptation, the channel is reported as unavailable...
I'm able to start the car, disengage the park brake and drive but I have ESP and ABS disabled currently.
Any suggestions appreciated.
Thanks
Abridged VCDS scan is in next post:
Thanks
