Originally posted by Passat R36
									View Post
		You would have to drive through a flood before it would cause a problem.
PS - the same scenario applies for Lamborghini / Ferrari / Mclaren / Koennigsegg etc. If it's OK for them, it's OK for me and should be OK for modifiers.
#Eurobahn - Have you monitored intake air temperature before and after this intake mod? In my prior custom intake mod version whereby I had a much larger POD filter fed with a directed stream of air from the factory scoop, I found IAT skyrocketed in traffic / idling. It would take high speed driving to get any benefit. It's not really a cold air intake.
Also, Eurobahn, did you get any errors from the Cat changeover? Did you have to fit resistors or ceramic bungs over the post Cat O2 sensors?
