Hi R36 and Passat CC V6 fans.
I wanted to share with you a DIY mod that improves performance of your R36 that only costs time, patience and the right tools.
I inspected and reviewed a few intakes for the R36 / CC V6. The Evoms produces a nice sound but ultimately has a couple flaws. First, it lets underbonnet hot air in near the exhaust manifold. This is a big No-No for performance and economy. Secondly, the filter is smaller in surface area than the original filter, which would outweigh any restriction improvement.
The net result is loss of performance and a waste of money (excluding the improvement to sound). The Gruppe unit is quite expensive & hard to find. I haven’t seen the filter nor the inner design to assess it.
So, I had a good look at the factory setup. It's pretty good mostly. I started by removing the AF sensor, then removed the metal screen behind the plastic grille. The metal screen serves to protect the AF sensor from stones etc but I will never have the Air Filter removed while the engine runs. It creates unnecessary turbulence and in one test I saw on Autospeed, they found an airflow improvement when removed. I then used electrical cleaner spray over the sensor electronics inside before reinstall.
I didn't remove the plastic grille as this controls the airflow over the sensor at lower RPM and would disrupt the performance.
The pipes leading to the airbox inlet over the radiator is made up of a few pieces. It’s an odd design, likely for Europe where snow / sleet and sub-zero temperatures. This part is not great for performance as it sucks both hot air and cold air. Also, the cold air path has to do a loop and so is not ideal. With my son, we had a look at how we can improve it. We came up with a great solution that has three benefits:
Benefit – More torque, more power, less fuel consumption due to needing less revs for the same amount of acceleration.
How it works- The hot air intake is sealed off, whilst the cold air airflow is straightened and opened for less restriction. Now the engine only sucks cold air from the front of the car - and at speed, this is slightly forced in (Ram Air). It’s a Win-Win.
HOW TO: (PS – Very hard to describe)
I’d be willing to do this for owners for $80. Just mail the part to me and I’ll mail it back. You can still drive ur R36 while u wait - No harm. PM me if you’d like me to do this for you. Otherwise, if you have the right tools and skills, DIY.
Bonus tweaks – Overcome the overkill designed for non-enthusiasts
- No more hot air induction
- Ram Air at speed – The possibility of slight supercharging effect
- When installed with cover, it looks completely original.
- Unclip and remove the top cover of the inlet pipe
- Unclip and remove the inlet pipe that fits between the air box inlet and the front ‘scoop’. It has a multi-inlet design
- Cut (with a hack-saw / dremel / small grinder) along the edges where the cold air blade of the inlet points up. The idea is to enable the cold-air ‘blade’ to flex.
- With a heat gun, protective gloves, patience, and good air-flow (toxic fumes), you heat up the ‘blade’ and apply pressure to make the blade fully flex down to the front inlet, whilst reshaping the outlet pipe back to original shape as the pressure causes it to deform.
- Clamp with a vice (or grips) the blade to the inlet and fill all small gaps with a sealant (exterior grade silicone or similar) whilst using it to fasten the blade to the inlet. Images: https://dl.dropboxusercontent.com/u/...2012.10.52.jpg and https://dl.dropboxusercontent.com/u/...2012.10.38.jpg
- The big gap created needs a different approach – I used expanding foam then cut it back once cured. I think heat resistant tape may be suitable as well.
- Leave it for a day to cure. You can still drive your R36, it will be sucking hot air so performance will drop slightly.
- Refit. https://dl.dropboxusercontent.com/u/...2009.36.12.jpg Then fit cover
- Use the same sealant to block a small hole at the bottom rear of the airbox. I believe it’s a secondary drain hole.
- Improve the airflow through the ‘scoop’ in your grille. This has two parts, on top of the grille, and between the grille fins. Using fine side-cutters, cut off all the scoops’ grille to reduce turbulence and restriction for an enhanced RAM Air Effect. These are designed to minimise large foreign materials (leaves, sticks, stones) entering you airbox, but most manufacturers don’t have them. The airbox will hold this rubbish fine, just clean out every service with a vacuum. IMAGES: from top https://dl.dropboxusercontent.com/u/...2016.58.47.jpg AND from front https://dl.dropboxusercontent.com/u/...2016.59.27.jpg
