Request a Passat owner MY09 or later with Dynaudio system
  • Request a Passat owner MY09 or later with Dynaudio system
    Hi All,
    I'm after an owner of a MY09 or later Passat with Dynaudio option.
    I need the part number of the amp under the passanger seat as well as a picture of the connector/harness if possible.
    Can anyone assist?
    Thanks
    I bet you have the same amp as mine right?
    2018 BMW 125i M Sport |AlpineWhite|719M JetBlack|BlackLeather |ComfortPackage|Sunroof|WirelessCharging
    2010 MY10 R36 Wagon | Biscay Blue | Power Tailgate | RNS510 | MDI | RVC | 51,000 km |Garage Open Button | Dead Pedal Mod | OE Fit DRL | VCDS | Sprint Booster | H&R Rear Sway Bar | Alcantara Steering Wheel | Dual Reverse Light | 19" Bentley Wheels (BBS Forged Split) | Michelin PS 4S
    2005 MY05 AH Astra HatchBlack | Facelifted SRi Looking | OpeliZed | Whiteline RSB | Eibach ProKit
      Yeah the one with a single connector, not two
        Here are 2 photos from my 2011 Passat wagon with Dynaudio. Can't see any serial numbers without removing from the mount unfortunately & I'm not too keen to take the connectors off either in case the car forgets it has an amp!
        Hope this is of some value anyway.
        MY12 B7 Tdi Highline Wagon | Reflex Silver | Sport Package | Dynaudio | Towbar
          Thanks very much for that 2 plug harness then for Dynaudio, single for VW sound system amp from MY09 on it would seem.
            I don't know if the link below to a guy doing an install on a CC is of any use but I am still keen on finding a way to retro fit the Dynaudio system in to R36 with the single plug.
            My R36 is the same with the later model single connector CBX RNS510 & Accessories: Dynaudio Retrofit
              Thanks I have read his work. I've posted links to a full harness which will allow a fairly painless install.
                Oh ok so this will be possible then ?
                I even spent last night going through forums in Germany reading through everything they had and could not find much info , if anything they would be referring sometimes to the info on our forums or elsewhere to gain a better understanding with certain mods.
                  Yeah its totally doable but not a trivial exercise. The whole wiring loom from head unit to all speakers and battery etc needs to be swapped out (or spliced to just replace the amp connectors.)
                    Yeah I came across pigtails for the Lear AMP on ebay for $30 I was thinking they could be wired in to the existing loom .
                      There has to be someone in Europe who makes a pnp connector, or could make one if they wanted to...just haven't come across them yet.
