Hi. How common is mechatronic connector/plug to leak fluid out of the pins/harness? Is this a bad sign? Can it be repaired?
Dq250 mechatronic plug leak
There is a breather hole in the middle of the plug.
Unless there are any fault codes or problematic behaviours, just clean it off.
Was the DSG overfilled at last service?
If the proper level procedure isn't used it's easy to over fill.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Hi. No fault codes. I will take the air box out to gain access and use some contact cleaner. Should I unplug it and clean inside it? Thanks.Originally posted by kamold View PostThere is a breather hole in the middle of the plug.
Update: I've cleaned it off and the leak has come back again. No error codes or drivability issues thus far. A little concerning still.Originally posted by kamold View PostThere is a breather hole in the middle of the plug.
