Hi all
I have a 2012 Passat with a 7 pin flat trailer socket. I'm trying to tow a camper trailer behind it which uses an ElecBrakes Bluetooth module to control/modulate the electric brakes on the trailer. The ElecBrakes unit is powered via the the park light circuit from the trailer socket (so need lights on to power the unit). It then needs to detect braking from the car (e.g. brake lights illuminate) to drive/modulate the electric brakes on the trailer (it has a plug and play adapter between the car trailer socket and the trailer plug). The issue is - it looks like I only have 1 wire for both the tail lights AND the brake lights on the Passat. The circuit runs 6-7v with lights on for tail, then 12-12.5v for brakes (regardless of lights being on or not).
All car brake lights are LED and all rear lights come on when lights are turned on - the tail lights just get brighter when I brake. The only exception to this is the brake light in the tailgate lid (only comes on when braking).
Has anyone experienced this problem/got a solution that doesn't involve going to an autoelec to hardwire a brake controller in via the blue wire (i.e. not using the ElecBrake unit)? The only thing I can think of is using the brake light off the top of the rear liftgate but I don't know what colour wire that is (there are about 10,000 wires going into each side of the lift gate and they're all white), I don't know what voltage it is even if I found it (ElecBrakes need 12v min), and the ElecBrake unit drops connectivity whenever I hit the brake as the surge from 6v to 12v on the tailight wire is resetting the connection.
Is there a smart ECU or something I can get which decifers tail from brake lights and gives me an extra wire??
Gareth
Edit:
ElecBrake is this > Elecbrakes Electric Trailer Brake Controller - ELBC2000-PS - Auto One
Elecbrake Adaptor is this > Elecbrakes Plug and Play Adapter Flat 7 Pin To Flat 7 Pin - A7-7 - Auto One
Photo attached of right tail light wires when we had it apart.
Gareth
Edit:
