Fuel gauge not working
  • Fuel gauge not working
    Greetings
    I've had a hiccup with the fuel gauge once before - it stopped working for a day or so and then it worked Ok until recently.
    I took the pump out and in my haste thinking it's the gauge sender unit changed it. To my disappointment it's not it. After I soldered the new sender unit in (big mistake) I've measured the old one and it seems it was actually working Ok. When I say OK - when measured the ohm values were changing depending on the position of the floater.
    So now, I've got the new sender unit soldered in and still no gauge. Again I measured the resistance of the new unit and it also appears to have changing resistance.
    What gives?
    2006 VW Passat Sedan 3.2lt AXZ, FSI 4motion, another milestone - 398K ... and still going
    What's the fault code in the cluster?
    That should give you a good idea what the issue is - is it short to ground or plus, is it resistance too high or too low
      Measuring the resistance at the cluster and comparing it to the reading you get from the sender, you may have a break in the cable somewhere.
        Thanks guys,
        I'll have to hook up the vcds and post any suspicious fault codes - well, the ones which were not previously there .
        When you say 'resistance at the cluster' do you mean the 3 pronged terminal sticking out of the top of the pump? as well as the cable connected to it?
        Edit - the below are the photos of the pump cover and top of the pump. The 'insulation work' on the plug was done prior to me acquiring the vehicle.
Name:	20230704_top fpump.jpg
ID:	1861276 Click image for larger version
          My old laptop's battery unfortunately is u/s so it took me a while to hook up the extension power cord to get the scan going. But in any case here it is:
          Thursday,03,August,2023,11:07:17:00009
          VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
          VCDS Version: 20.12.0.0
          Data version: 20201124 DS322.0
          www.Ross-Tech.com
          Repair Order: 03082023
          Chassis Type: 3C-VW46 (3C0)
          Scan: 01 02 03 08 09 15 16 17 19 22 25 36 42 44 46 52 53 56 62 65
          69 72 76
          VIN: WVWZZZ3CZ6P178475 Mileage: 350510km-217796miles
          01-Engine -- Status: Cannot be reached 1100
          02-Auto Trans -- Status: Cannot be reached 1100
          03-ABS Brakes -- Status: Cannot be reached 1100
          04-Steering Angle -- Status: Cannot be reached 1100
          08-Auto HVAC -- Status: Cannot be reached 1100
          09-Cent. Elect. -- Status: Malfunction 0010
          15-Airbags -- Status: Cannot be reached 1100
          16-Steering wheel -- Status: OK 0000
          17-Instruments -- Status: Malfunction 0010
          19-CAN Gateway -- Status: Malfunction 0010
          22-AWD -- Status: Cannot be reached 1100
          25-Immobilizer -- Status: OK 0000
          36-Seat Mem. Drvr -- Status: Malfunction 0010
          42-Door Elect, Driver -- Status: Malfunction 0010
          44-Steering Assist -- Status: Cannot be reached 1100
          46-Central Conv. -- Status: Malfunction 0010
          52-Door Elect, Pass. -- Status: Malfunction 0010
          53-Parking Brake -- Status: Cannot be reached 1100
          56-Radio -- Status: Malfunction 0010
          62-Door, Rear Left -- Status: OK 0000
          65-Tire Pressure -- Status: OK 0000
          69-Trailer -- Status: Cannot be reached 1100
          72-Door, Rear Right -- Status: OK 0000
          76-Park Assist -- Status: OK 0000
          Address 01: Engine Labels: 03H-906-032-BLV.clb
          Part No SW: 03H 997 033 K HW: Hardware No
          Component: P3.2 FSI-EU4 G00 2368
          Revision: --H11--- Serial number: VWZCZ000000000
          Coding: 0000175
          Shop #: WSC 00028 028 00001
          VCID: 356194D35C417F2CE0-8060
          1 Fault Found:
          012555 - Low Pressure Fuel regulation
          P310B - 004 - Fuel Pressure Outside Specification
          Freeze Frame:
          Fault Status: 01100100
          Fault Priority: 0
          Fault Frequency: 157
          Reset counter: 255
          Mileage: 347856 km
          Time Indication: 0
          Date: 2023.05.19
          Time: 07:03:22
          Freeze Frame:
          RPM: 635 /min
          Load: 28.6 %
          Speed: 1.0 km/h
          Temperature: 72.0°C
          Temperature: 29.0°C
          Absolute Pres.: 990.0 mbar
          Voltage: 13.716 V
          Readiness: 0000 0000
          Address 02: Auto Trans Labels: 02E-927-770.clb
          Part No SW: 02E 300 047 J HW: 02E 927 770 AE
          Component: GSG DSG 070 1154
          Revision: 04507000 Serial number: 00000602071105
          Coding: 0000020
          VCID: 1F4D567BCEBDD57C1A-804A
          No fault code found.
          Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
          Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
          Component: ESP 440 C2 H015 0003
          Revision: H015 Serial number: 0667165431
          Coding: 0046535
          VCID: 306FA5C7A3235A04B3-8064
          1 Fault Found:
          00778 - Steering Angle Sensor (G85)
          008 - Implausible Signal - Intermittent
          Freeze Frame:
          Fault Status: 00101000
          Fault Priority: 3
          Fault Frequency: 12
          Reset counter: 142
          Mileage: 350068 km
          Time Indication: 0
          Date: 2023.07.18
          Time: 22:59:39
          Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
          Part No SW: 5K0 907 044 EA HW: 5K0 907 044 EA
          Component: Climatronic H17 1010
          Revision: 00003001
          Coding: 0000001002
          Shop #: WSC 01324 020 00200
          ASAM Dataset: EV_Climatronic A01010
          ROD: EV_ClimaAutoBasis_VW46.rod
          VCID: 6ED37BBFB1970CF4E1-803A
          1 Fault Found:
          13701456 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
          Confirmed - Tested Since Memory Clear
          Freeze Frame:
          Fault Status: 00000001
          Fault Priority: 6
          Fault Frequency: 1
          Reset counter: 104
          Mileage: 350514 km
          Date: 2023.07.31
          Time: 11:08:28
          Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
          Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
          Component: Bordnetz-SG H37 1301
          Revision: 00H37000 Serial number: 00000003835219
          Coding: E1848F0700041A00000A00000F00000000085D435C0000
          Subsystem 1 - Part No: 3C2 955 119 Labels: 1KX-955-119.CLB
          Component: Wischer VW461 012 0503
          Coding: 00063445
          Shop #: WSC 00028
          Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
          Component: RegenLichtSens 011 1110
          Coding: 00208933
          Shop #: WSC 00028
          5 Faults Found:
          02394 - Parking Light Left Front (M1)
          012 - Electrical Fault in Circuit - Intermittent
          Freeze Frame:
          Fault Status: 00101100
          Fault Priority: 2
          Fault Frequency: 5
          Reset counter: 143
          Mileage: 349923 km
          Time Indication: 0
          Date: 2023.07.16
          Time: 06:25:00
          Freeze Frame:
          ON
          Voltage: 11.80 V
          ON
          ON
          OFF
          OFF
          OFF
          01496 - Bulb for Fog-Lamps; Left (L22)
          010 - Open or Short to Plus - Intermittent
          Freeze Frame:
          Fault Status: 00101010
          Fault Priority: 4
          Fault Frequency: 20
          Reset counter: 130
          Mileage: 348055 km
          Time Indication: 0
          Date: 2023.05.22
          Time: 18:01:00
          Freeze Frame:
          ON
          Voltage: 13.85 V
          ON
          ON
          OFF
          OFF
          OFF
          01500 - Bulb for Fog-Lamps; Right (L23)
          Freeze Frame:
          Fault Priority: 4
          Fault Frequency: 12
          Reset counter: 130
          Mileage: 348055 km
          Time Indication: 0
          Date: 2023.05.22
          Time: 18:00:00
          Freeze Frame:
          ON
          Voltage: 13.80 V
          ON
          ON
          OFF
          OFF
          OFF
          01517 - Control Module for Trailer/Towing Sensor (J345)
          004 - No Signal/Communication - Intermittent
          Freeze Frame:
          Fault Status: 00100100
          Fault Priority: 2
          Fault Frequency: 254
          Reset counter: 144
          Mileage: 347974 km
          Time Indication: 0
          Date: 2023.05.21
          Time: 13:28:00
          Freeze Frame:
          OFF
          Voltage: 13.20 V
          OFF
          ON
          OFF
          OFF
          OFF
          01320 - Control Module for Climatronic (J255)
          Freeze Frame:
          Fault Priority: 2
          Reset counter: 144
          Mileage: 347974 km
          Time Indication: 0
          Date: 2023.05.21
          Time: 13:28:00
          Freeze Frame:
          OFF
          Voltage: 13.25 V
          OFF
          ON
          OFF
          OFF
          OFF
            Address 15: Airbags Labels: 3C0-909-605.lbl
            Part No SW: 3C0 909 605 K HW: 3C0 909 605 K
            Component: 17 AIRBAG VW8R 029 2521
            Revision: 10029000 Serial number: 003A3P1ZPVBF
            Coding: 0012599
            VCID: 2E53BBBFB9174CF4A1-807A
            Subsystem 1 - Serial number: 6332MSME0F5F0E3BY
            Subsystem 2 - Serial number: 6342MSME0F49367AQ
            Subsystem 3 - Serial number: 6351HTS64IKAP662E
            Subsystem 4 - Serial number: 6361HTS64IKQDAR21
            Subsystem 5 - Serial number: 00000000000000000
            Subsystem 6 - Serial number: 00000000000000000
            Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
            Part No SW: 3C0 953 549 E HW: 3C0 953 549 E
            Component: J0527 0015
            Revision: 00005000 Serial number: 3C5953507P
            Coding: 0001111
            Subsystem 1 - Part No: XXXXXXXXXXX
            Component: E0221 007 0050
            Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
            Part No SW: 3C0 920 870 P HW: 3C0 920 870 P
            Component: KOMBIINSTRUMENT VD1 4240
            Revision: X0033000 Serial number: 00000000000000
            Coding: 0007705
            Shop #: WSC 30081 959 88100
            2 Faults Found:
            00438 - Fuel Supply Sensor 2 (G169)
            003 - Mechanical Failure
            Freeze Frame:
            Fault Status: 01100011
            Fault Priority: 2
            Fault Frequency: 1
            Reset counter: 59
            Mileage: 349196 km
            Time Indication: 0
            Date: 2023.06.24
            Time: 20:27:36
            Freeze Frame:
            Fault Priority: 2
            Fault Frequency: 2
            Reset counter: 138
            Mileage: 350289 km
            Time Indication: 0
            Date: 2023.07.26
            Time: 17:08:55
            Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
            Part No SW: 3C0 907 530 Q HW: 3C0 907 951
            Component: J533 Gateway H13 0172
            Revision: H13 Serial number: 3640P151190AC5
            Coding: FD82FF4F00020200F103
            Shop #: WSC 12345 123 12345
            VCID: 2F6DA6BBBE1D45FCAA-807A
            2 Faults Found:
            Freeze Frame:
            Fault Priority: 2
            Reset counter: 144
            Mileage: 347974 km
            Time Indication: 0
            Freeze Frame:
            Fault Priority: 2
            Reset counter: 144
            Mileage: 347974 km
            Time Indication: 0
            Address 22: AWD Labels: 1K0-907-554.lbl
            Part No: 1K0 907 554 C
            Component: HALDEX 4Motion 0108
            Coding: 0000001
            Shop #: WSC 00000 000 00000
            VCID: 2D51BCB3B41137EC98-8078
            Address 25: Immobilizer Labels: 3C0-959-433-25.clb
            Part No SW: 3C0 959 433 P HW: 3C0 959 433 P
            Component: IMMO 043 0364
            Revision: 00043000 Serial number: VWZCZ000000000
            Shop #: WSC 131071 1023 2097151
            VCID: 377D9EDB464D8D3CF2-8062
            Subsystem 1 - Part No: 3C0 905 861 D
            Component: ELV 024 0370
            3C0905861D ELV 024 0370
            Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
            Part No SW: 3C0 959 760 B HW: 3C0 959 760 B
            Component: Sitzverstellung 0701
            Revision: 00003000 Serial number: 00000000000000
            VCID: 2C57B1B78F0B3EE48F-8078
            Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
            Part No: 1K0 959 701 L
            Component: Tuer-SG 024 2462
            Coding: 0000951
            1 Fault Found:
            00131 - Outside Door Handle Illumination/mirror Light Driver Side
            Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
            Part No: 1K2 909 144 K
            Component: EPS_ZFLS Kl.5 D06 1701
            VCID: 3467A9D7573B6624D7-8060
            Address 46: Central Conv. Labels:. 3C0-959-433-46.clb
            Component: KSG PQ46 RDK 043 0213
            Coding: 01910A0801860E76380694157008DFCE101800
            Subsystem 1 - Part No: 1K0 951 605 C
            Component: LIN BACKUP HORN H03 1301
            Subsystem 2 - Part No: 3C0 951 171 A
            Component: Neigungssensor 002 0508
            Subsystem 3 - Part No: 3C0 951 171 A
            Component: Innenraumueberw.002 0508
            2 Faults Found:
            Freeze Frame:
            Fault Priority: 4
            Reset counter: 144
            Mileage: 347974 km
            Time Indication: 0
            Date: 2023.05.21
            Time: 13:28:24
            Freeze Frame:
            Fault Priority: 4
            Reset counter: 144
            Mileage: 347974 km
            Time Indication: 0
            Date: 2023.05.21
            Time: 13:28:24
              Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
              Part No: 1K0 959 702 L
              Coding: 0000950
              VCID: 387F9DE74B538244FB-806C
              1 Fault Found:
              00132 - Outside Door Handle Illumination/mirror Light Passenger Side
              Address 53: Parking Brake Labels: 3C0-907-801-53.clb
              Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
              Component: EPB VC8HC001 013 0001
              Revision: 013
              Coding: 0000012
              Shop #: WSC 30087 959 68769
              VCID: 21495083F8C9E38C2C-8074
              Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
              Part No SW: 3AD 035 190 A HW: 3AD 035 190 A
              Component: RCD510USBRVC 003 0003
              Revision: -----001 Serial number: VWZ4Z3P8053234
              Coding: 01000425040010
              Shop #: WSC 00079 790 12345
              VCID: 2B55B2AB4A0539DC86-807E
              1 Fault Found:
              01317 - Control Module in Instrument Cluster (J285)
              Freeze Frame:
              Fault Priority: 6
              Fault Frequency: 1
              Reset counter: 14
              Mileage: 347908 km
              Time Indication: 0
              Date: 2023.05.20
              Time: 14:47:44
              Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
              Part No: 1K0 959 703 F
              Component: Tuer-SG 021 2432
              Coding: 0000144
              VCID: 3365AACB5235611CCE-8066
              Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
              Component: RDK 0391
              Coding: 0161210
              Address 69: Trailer Labels: 1K0-907-383-V1.clb
              Part No SW: 1K0 907 383 HW: 1K0 907 383
              Component: ANHAENGERELEKTR 003 0020
              Coding: 0000001
              VCID: 6ADB77AF457FE0D4BD-803E
              Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
              Part No: 1K0 959 704 F
              Coding: 0000144
              Address 76: Park Assist Labels: 3C0-919-283.lbl
              Part No SW: 3C0 919 283 B HW: 3C0 919 283 B
              Component: Parkhilfe 8-Kan 004 0011
              Revision: 00004000 Serial number: 82930602501458
              Coding: 0011014
              VCID: 285F4DA79BF312C46B-807C
              End-------------------------(Elapsed Time: 02:49)--------------------------
                Code:
                2 Faults Found:
                Freeze Frame:
                Fault Priority: 2
                Fault Frequency: 1
                Reset counter: 59
                Mileage: 349196 km
                Time Indication: 0
                Date: 2023.06.24
                Time: 20:27:36
                Freeze Frame:
                Fault Priority: 2
                Fault Frequency: 2
                Reset counter: 138
                Mileage: 350289 km
                Time Indication: 0
                Date: 2023.07.26
                Time: 17:08:55
                I would guess there is an open circuit somewhere. Check out this wiring diagram; I would be checking the plug at the cluster a 36-pin and checking its connectivity to the 3-pin connector at the tank.
                  Originally posted by MIG View Post
                  Code:
                  2 Faults Found:
                  Freeze Frame:
                  Fault Priority: 2
                  Fault Frequency: 1
                  Reset counter: 59
                  Mileage: 349196 km
                  Time Indication: 0
                  Date: 2023.06.24
                  Time: 20:27:36
                  Freeze Frame:
                  Fault Priority: 2
                  Fault Frequency: 2
                  Reset counter: 138
                  Mileage: 350289 km
                  Time Indication: 0
                  Date: 2023.07.26
                  Time: 17:08:55
                  [ATTACH=CONFIG]55381[/ATTACH]
                  Thanks for the information MIG
                  I'm hoping it's not the 'new' sender unit I installed (seems unnecessarily) about a week ago. I did check it's resistance prior to fitting and it appeared to be working Ok. That 3 pronged plug on the top of the pump seem OK too - from memory there was a continuity between. at least, 2 terminals? However, if all 3 have to have continuity then something is NQR. I'll have to re-check this again.
                  As to the T36 connector - where exactly does it plug in? Must be somewhere at the back of the cluster display? So, this could be 'the cluster' you guys were talking about. If so, I'd have to research how to take the cluster out to check that connector.
                    Maybe go back to the basics before pulling the cluster.
                    Check the three pins first.
                    One pin should be to ground (pin1 brown\blue); one should be a reference voltage and the other the sense wire for the sender.
                    Maybe look under that tape mess
                      There is a useful post on the Ross Tech forum which explains the differences between short to plus, short to ground faults etc:
                      Testing - Open Circuits, Short to Ground or Positive, etc.... | Ross-Tech Forums
                        Thanks - it'll be tonight's reading
                          Today I've tried troubleshooting this
                          1 - checking the plug (as below - ignition on) resulted in 0.9V between the connector 2-3 blue purple/white wire and 0V on brown/blue stripe earth? wire.
                          2 - Testing for Short to Ground (as per Ross Tech) produced battery voltage 0.9V
                          3 - Testing for Short to Positive (as per Ross Tech) showed 12V.
                          There does not seem to be a specific fuse to cover fuel gauge that I could find? but is there any way to power up and check the gauge itself?
                            An update (sort of) - I've had one of the TTY guys have a look at this for me. Despite swapping Fuel Pump Controller (from R36 I think it was), both fuel sender units he was unable to pinpoint where the fault is. In any case the fuel sender units (in the car) were testing a moving resistance and the fuel gauge itself needle could be moved using the VCDS so unlikely indicating a mechanical fault to the gauge itself.
                              Hi,
                              Maybe a longshot...
                              I had a fuel supply issue a couple of years back with a low fuel pressure sensor fault. Long story short, once the sensor was replaced and couple of other bits, all the hardware was good, save for the gauge measuring. Turned out the coding for the gauge was corrupted. The tank characteristic curve for the left tank (from memory) was missing and the gauge 'code' could only see one tank. Therefore, fuel load was incorrectly calculated (not helpfully, above what was in the tanks) so just over half full on the gauge was empty tanks.
                              Perhaps check the tank characteristic curves in the coding for your dash. (I note mine is a later dash than yours)
                              R36 Wagon MY2010.5: Biscay Blue| Dynaudio and Nav| RVC| VW tow bar|
                              Mod highlights:
                              ECU and DSG Tune| 3AA CCM and 7N0 Gateway| 3D colour MFD| MIB2 retrofit and 7N0 RVC| Quad LED tail, brake and indicator rings| Zimmermann Sportbrake rotors, composite pads| TPMS High| 2Q0 Blind Spot and RCTA| B8 rearview mirror|
