I got myself the lovely error message of "Steering column lock faulty" and a red flashing wheel on the way home this afternoon.
02861 - Electronic Steering Column Lock Check Sum Error
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 254
Mileage: 147228 km
Time Indication: 0
Date: 2023.07.18
Time: 17:14:04
I saw the error was mentioned here too https://www.vwwatercooled.com/forums...ighlight=02861
Now I know the microswitch fail on these units, and I have the tools to swap those over, also ~2 hours of reaching catalogues, I found the OEM part Access to this page has been denied.
But after looking at when the micro switches fail, it sets other codes on the module, so I am not sure what is wrong with my unit at this point in time.
So my options are, what do you think I should do?
Replace the lock module + reprogram it (Needs access to ODIS \ GEKO)
Replace the lock module + transfer MCU chip (The problem may be with the chips eeprom and this won't fix it)
Replace the microswitches and relays in the module.
Wait until the issue worsens and sets the other codes, but maybe get stranded.
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 254
Mileage: 147228 km
Time Indication: 0
Date: 2023.07.18
Time: 17:14:04
