I have a feeling my catalyst are failing or blocked on my R36, as previous issues with misfire, performance and exhaust note change.
At what temperatures are normal for cats on both banks? Done a idle test via VCDS , outside temp were 2 degrees. Output test temp were around 765 degrees. ? Is this acceptable ?
Will try doing pressure test to see later on
