G-8VXWWTRHPN Sourcing Specialty Tool - T40159 - VWWatercooled Australia
  • Sourcing Specialty Tool - T40159
    Hey,
    First post here and probably one of many... I was reading erWIN for the removal of a sump on a 3.6 passat and saw it requires specialty tool T40159 to remove 3 bolts on the gearbox side (I believe its an extra long triple square round-head M8 to reach past the flywheel).
    Just curious if anyone knows where I can get one of these at short notice, or possibly rent/borrow(with a worthwhile deposit of course) from any users in the Sydney Metro area?
    I looked at an image of this tool. It's beautifully sculptured with a narrow-waisted shaft. However I don't see why a normal long triple square M8 socket available at many tool shops couldn't do the job. The head is the widest part, so the diameter of the shaft shouldn't matter. Or am I missing something?
    2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
    Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
      VW Ball End XZN-8 Socket
