What part number to order replacement or recommend better than stock, thanks
Intercooler for VW Passat 125 TDI 2009
Should be the same intercooler as used on the same era VW Golf.
Standard replacement: INTERCOOLER VW PASSAT B6 CC 1,9 2,0 TDI 1,8 2,0 TSI 2005- 1K0145803B 3C0145805G | eBay
Alloy standard aftermarket: Aluminum Intercooler For VW Golf Jetta MK5/6 Passat B6 B7 Audi A3/S3 2.0 FSI TSI | eBay
Upgrade (there are cheaper options - starting at around $600 up to about $2000): Wagner Tuning VW MK5 MK6 1.6 2.0 TDI Golf Jetta Passat Caddy Competiti – Performance Brands
Are you planning on a turbo upgrade too?
I have a new one with upgraded billet impeller sitting around that *may* happen to fit your engine.. AFAIK - it's for a newer CB* engine, where mine's a BMR... it's supposed to spool up quicker and support more boost etc. It came with a graph.
2018 Arteon R-Line - Black, Sunroof, Dynaudio, 20" Wheels, RacingLine: Stage 2 ECU+DSG|380mm BBK|Intercooler+Hoses|Oil Cooler|R600 Intake|Adjustable Front Droplinks|Dogbone Insert|Subframe Brace+Alignment Kit|Propshaft Alignment Kit, Milltek: Zirotec Downpipe, Harding: Front+Rear Sway Bars|Rear Droplinks, Other: OSRAM Dynamic Indicators, EvcX Throttle Controller, 034 (RED) Coil Packs, Various Carbon Bits
Originally posted by Mylotian View PostThanks I've had stage 1 tuning done looking at stage 2 optionsThey're a torquie little motor.
You may need to consider DSG upgrades too though. You probably have a DQ200, which (IIRC) is relatively limited in how much torque it can handle.Last edited by nermal; 03-08-2022, 04:22 PM.2018 Arteon R-Line - Black, Sunroof, Dynaudio, 20" Wheels, RacingLine: Stage 2 ECU+DSG|380mm BBK|Intercooler+Hoses|Oil Cooler|R600 Intake|Adjustable Front Droplinks|Dogbone Insert|Subframe Brace+Alignment Kit|Propshaft Alignment Kit, Milltek: Zirotec Downpipe, Harding: Front+Rear Sway Bars|Rear Droplinks, Other: OSRAM Dynamic Indicators, EvcX Throttle Controller, 034 (RED) Coil Packs, Various Carbon Bits
