I can't recall, but I'll plug in tomorrow and have a look.
On the Pump, I did look at it, but sourcing the filters in a time-line that worked for me was problematic, so I ended up buying new OEM VW pump and fitting it myself. I did try and get an aftermarket one, which would have been a quarter of the price for basically the same bits of plastic, but getting an R36 version here was very problematic. On the filters, you should be able to get the parts you'd need to do it in the UK/Europe. If you do need/want to pull the pump, disconnect the negative from the battery as the fuel module is sensitive (local VW parts place advised it was a good idea), it's the blue module on top of the sealing lid on top of pump.
