I turns out - even though the EPB Control Module has the same part number it comes from a non-rear EPB car (2Lt TDI model). I'm curious if despite that it still could be coded to work in my car? Has anyone had any experience with that?
Replacing rear brake pads causes EPB fault
Post the actual faults from VCDS.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Here is the faults log:Originally posted by kamold View PostPost the actual faults from VCDS.
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 36 42 44 46 52 53 56 62 65
69 72 76
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 03H-906-032-BLV.clb
Part No SW: 03H 997 033 K HW: Hardware No
Component: P3.2 FSI-EU4 G00 2368
Revision: --H11--- Serial number: VWZCZ000000000
Coding: 0000175
Shop #: WSC 00028 028 00001
VCID: 356194D35C417F2CE0-8060
3 Faults Found:
005715 - Please check DTC Memory of ABS Controller
P1653 - 004 -
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 317271 km
Time Indication: 0
Date: 2021.04.09
Time: 01:27:32
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 58.0°C
Temperature: 43.0°C
Absolute Pres.: 990.0 mbar
Voltage: 12.319 V
P1653 - 001 -
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 317271 km
Time Indication: 0
Date: 2021.04.09
Time: 01:27:35
Freeze Frame:
RPM: 1286 /min
Load: 34.9 %
Speed: 0.0 km/h
Temperature: 58.0°C
Temperature: 43.0°C
Voltage: 11.684 V
012555 - Low Pressure Fuel regulation
P310B - 004 - Fuel Pressure Outside Specification - Intermittent
Freeze Frame:
Fault Status: 00110100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 317278 km
Time Indication: 0
Date: 2021.04.13
Time: 03:26:16
Freeze Frame:
RPM: 2304 /min
Load: 46.6 %
Speed: 19.0 km/h
Temperature: 86.0°C
Temperature: 21.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.224 V
Readiness: 0110 0101
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 047 J HW: 02E 927 770 AE
Component: GSG DSG 070 1154
Revision: 04507000 Serial number: 00000602071105
Coding: 0000020
VCID: 1F4D567BCEBDD57C1A-804A
2 Faults Found:
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 255
Reset counter: 1
Mileage: 317271 km
Time Indication: 0
Date: 2021.04.09
Time: 01:27:18
00473 - Control Module for Elect. Park/Hand Brake (J540)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 0
Reset counter: 40
Mileage: 317271 km
Time Indication: 0
Date: 2021.04.09
Time: 01:32:03
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
Component: ESP 440 C2 H015 0003
Revision: H015 Serial number: 0667165431
Coding: 0010000
VCID: 306FA5C7A3235A04B3-8064
6 Faults Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 317283 km
Time Indication: 0
Date: 2021.04.13
Time: 00:05:58
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 317283 km
Time Indication: 0
Date: 2021.04.13
Time: 00:05:58
01542 - Yaw Rate Sensor (G202)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 317283 km
Time Indication: 0
Date: 2021.04.13
Time: 00:05:58
01423 - Lateral Acceleration Sensor (G200)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 317283 km
Time Indication: 0
Date: 2021.04.13
Time: 00:05:58
01279 - Longitudinal Acceleration Sensor (G251)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 317283 km
Time Indication: 0
Date: 2021.04.13
Time: 00:05:58
00810 - Sensor 1/2 for Brake Pressure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 317283 km
Time Indication: 0
Date: 2021.04.13
Time: 00:05:58
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 BB HW: 3C0 907 044 BB
Component: ClimatronicPQ46 112 0606
Revision: 00112021 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 62CB1F8FBD4FB89475-8036
No fault code found.
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000003835219
Coding: E1848F0700041A00000A00000F00000000085D435C0000
Subsystem 1 - Part No: 3C2 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 00028
Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Coding: 00208933
Shop #: WSC 00028
1 Fault Found:
01500 - Bulb for Fog-Lamps; Right (L23)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 137
Mileage: 317283 km
Time Indication: 0
Date: 2021.04.13
Time: 00:05:00
Freeze Frame:
ON
Voltage: 12.90 V
ON
ON
OFF
OFF
OFF
This is the first part of the fault log as the forum will not allow me to post more than 10000 characters2006 VW Passat Sedan 3.2lt AXZ, FSI 4motion, another milestone - 398K ... and still going
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 K HW: 3C0 909 605 K
Component: 17 AIRBAG VW8R 029 2521
Revision: 10029000 Serial number: 003A3P1ZPVBF
Coding: 0012599
VCID: 2E53BBBFB9174CF4A1-807A
Subsystem 1 - Serial number: 6332MSME0F5F0E3BY
Subsystem 2 - Serial number: 6342MSME0F49367AQ
Subsystem 3 - Serial number: 6351HTS64IKAP662E
Subsystem 4 - Serial number: 6361HTS64IKQDAR21
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 E HW: 3C0 953 549 E
Component: J0527 0015
Revision: 00005000 Serial number: 3C5953507P
Coding: 0001111
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 007 0050
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 870 P HW: 3C0 920 870 P
Component: KOMBIINSTRUMENT VD1 4240
Revision: X0033000 Serial number: 00000000000000
Coding: 0007705
Shop #: WSC 30081 959 88100
Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 Q HW: 3C0 907 951
Component: J533 Gateway H13 0172
Revision: H13 Serial number: 3640P151190AC5
Coding: FD82FF4F00020200F103
Shop #: WSC 12345 123 12345
VCID: 2F6DA6BBBE1D45FCAA-807A
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 C
Component: HALDEX 4Motion 0108
Coding: 0000001
VCID: 2D51BCB3B41137EC98-8078
1 Fault Found:
01316 - ABS Control Module
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 P HW: 3C0 959 433 P
Component: IMMO 043 0364
Revision: 00043000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 377D9EDB464D8D3CF2-8062
Subsystem 1 - Part No: 3C0 905 861 D
Component: ELV 024 0370
3C0905861D ELV 024 0370
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 B HW: 3C0 959 760 B
Component: Sitzverstellung 0701
Revision: 00003000 Serial number: 00000000000000
VCID: 2C57B1B78F0B3EE48F-8078
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1K0 959 701 L
Component: Tuer-SG 024 2462
Coding: 0000951
1 Fault Found:
00131 - Outside Door Handle Illumination/mirror Light Driver Side
012 - Electrical Fault in Circuit - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K2 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 3467A9D7573B6624D7-8060
1 Fault Found:
000 - -
Address 46: Central Conv. Labels:. 3C0-959-433-46.clb
Component: KSG PQ46 RDK 043 0213
Coding: 01910A0801860E76380494157008DFCE101800
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 3C0 951 171 A
Component: Neigungssensor 002 0508
Subsystem 3 - Part No: 3C0 951 171 A
Component: Innenraumueberw.002 0508
1 Fault Found:
01517 - Control Module for Trailer/Towing Sensor (J345)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 11
Reset counter: 177
Mileage: 317271 km
Time Indication: 0
Date: 2021.04.09
Time: 01:35:38
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1K0 959 702 L
Coding: 0000950
VCID: 387F9DE74B538244FB-806C
1 Fault Found:
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0010000
Shop #: WSC 30087 959 68769
VCID: 21495083F8C9E38C2C-8074
3 Faults Found:
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 3
Fault Frequency: 254
Reset counter: 137
Mileage: 317264 km
Time Indication: 0
Date: 2021.04.13
Time: 03:17:07
Freeze Frame:
Voltage: 11.90 V
Count: 236
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 4
Fault Frequency: 4
Reset counter: 136
Time Indication: 0
Freeze Frame:
Voltage: 12.01 V
Count: 171
01087 - Basic Setting Not Performed
000 - - - MIL ON
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 136
Time Indication: 0
Freeze Frame:
Voltage: 12.01 V
Count: 170
-------------------------------------------------------------------------2006 VW Passat Sedan 3.2lt AXZ, FSI 4motion, another milestone - 398K ... and still going
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 3AD 035 190 A HW: 3AD 035 190 A
Component: RCD510USBRVC 003 0003
Revision: -----001 Serial number: VWZ4Z3P8053234
Coding: 01000424040010
Shop #: WSC 00079 790 12345
VCID: 2B55B2AB4A0539DC86-807E
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 136
Mileage: 317271 km
Time Indication: 0
Date: 2021.04.09
Time: 01:25:20
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 F
Component: Tuer-SG 021 2432
Coding: 0000144
VCID: 3365AACB5235611CCE-8066
Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
Component: RDK 0391
Coding: 0161211
1 Fault Found:
00667 - Ambient Temperature Signal
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00111000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 177
Mileage: 317283 km
Time Indication: 0
Date: 2021.04.13
Time: 00:01:04
Address 69: Trailer Labels: 1K0-907-383-V1.clb
Part No SW: 1K0 907 383 HW: 1K0 907 383
Component: ANHAENGERELEKTR 003 0020
Coding: 0000001
VCID: 6ADB77AF457FE0D4BD-803E
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 F
Coding: 0000144
Address 76: Park Assist Labels: 3C0-919-283.lbl
Part No SW: 3C0 919 283 B HW: 3C0 919 283 B
Component: Parkhilfe 8-Kan 004 0011
Revision: 00004000 Serial number: 82930602501458
Coding: 0011014
VCID: 285F4DA79BF312C46B-807C
End-------------------------(Elapsed Time: 02:26)--------------------------
Disregard the following (previous to EPB control module change) faults:
00132 - Outside Door Handle Illumination/mirror Light Passenger Side2006 VW Passat Sedan 3.2lt AXZ, FSI 4motion, another milestone - 398K ... and still going
Your ABS is not coded.
Try setting to 0015815.
Also EPB is not coded. Try 0000057.
Then carrying out the required calibrations per the Ross-tech wiki for G200, G201, G85, EPB etc.Last edited by kamold; 16-04-2021, 10:33 AM.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Thanks kamold, will give it a go tomorrow. Do these require Security Pin?
Reason I ask - when I went to coding? or adaptation? (can't recall but I think it was in the ABS) there was a specific setting for different types engines but when I selected 3.2 B6 it nonetheless came back with an error message.2006 VW Passat Sedan 3.2lt AXZ, FSI 4motion, another milestone - 398K ... and still going
No security access required
Sent from my SM-G960F using Tapatalk2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Thanks kamold,
So, the setting for ABS - 0015815 was accepted and I went on with calibrations as per Ross-Tech Wiki. Check of the parameters against Wiki showed mine were within values given. However, the ABS, Stability Control and the EPC warning lights are still On. The Stability Control switch light (near gear shift) is On and I still can't turn it Off (to get the Stability Control back On)
The EPB code 0000057 wasn't accepted. I kept trying different settings to get EPB fault cleared as I recall reading that sometimes it may not work straight away and might take 2-3 goes. Eventually, I got the right EPB actuator to work by using the "close brake pads" option (after renewal). After that I was able to clear the EPB control module faults and now the EPB works Ok.
However, I still have:
01 Engine showing malfunction: P1653 please check DTC Memory of ABS Controller and a new one P1479 Brake Boost Vacuum System - mechanical failure.
02 Auto Trans - GSG DSG P1847 please check DTC Memory of ABS Controller
03 ABS brakes - Vacuum Sensor for Brake Booster (G483) and Longitudinal Acceleration Sensor (G251) No or Incorrect Basic Setting/Adaptation though I think I got that (G251) "fixed" after I saved the faults list. I'll have to re-check that one tomorrow.
44 Steering Assist - Steering Limit Stop - 005 No or Incorrect Basic Setting/Adaptation (I'll have to re-check that one tomorrow again as I might have also got it fixed)
All-in-all a progress of sorts but I'm hesitant to use the car "as is" especially with the ABS & Stability Control MIL On.2006 VW Passat Sedan 3.2lt AXZ, FSI 4motion, another milestone - 398K ... and still going
Do you have a record of your ABS coding? You need to restore the correct coding.
That's what's causing the P1479 fault.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
I persevered PM today and managed to switch ALL the MIL (on the dashboard) off however ... these are the remaining faults as reported by VCDS:Originally posted by kamold View PostDo you have a record of your ABS coding? You need to restore the correct coding.
Coding: 0000175
3 Faults Found:
P1653 - 004 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 28
Reset counter: 255
Mileage: 317285 km
Time Indication: 0
Date: 2021.04.15
Time: 00:18:25
Freeze Frame:
RPM: 612 /min
Load: 23.1 %
Speed: 0.0 km/h
Temperature: 85.0°C
Temperature: 63.0°C
Voltage: 13.716 V
005241 - Brake Boost Vacuum System
P1479 - 008 - Mechanical Failure
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 317285 km
Time Indication: 0
Date: 2021.04.15
Time: 00:18:27
Freeze Frame:
RPM: 615 /min
Load: 22.0 %
Speed: 0.0 km/h
Temperature: 85.0°C
Temperature: 63.0°C
Voltage: 13.716 V
012555 - Low Pressure Fuel regulation (disregard this one)
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 317292 km
Time Indication: 0
Date: 2021.04.15
Time: 13:12:08
Freeze Frame:
RPM: 1043 /min
Load: 20.0 %
Speed: 16.0 km/h
Temperature: 55.0°C
Temperature: 20.0°C
Voltage: 14.224 V
Readiness: 0000 0000
Coding: 0015815
1 Fault Found:
02543 - Vacuum Sensor for Brake Booster (G483)
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 140
Mileage: 317367 km
Time Indication: 0
Date: 2021.04.16
Time: 19:09:11
Everything else is "No fault code found." The only other suspicious one is
Address 22: AWD Labels: None
VCID: 55A13453BC015F2C00-8000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
but I run out of time tonight.
As for the ABS coding I used the documented basic settings:
the ticks in Bits 3,4 & 5 appeared when I coded Bit 2 for 3.2Lt AWD engine & transmission.
BTW to remove the EPB faults I used the option "Test Parking Brakes" after which the EPB faults cleared.2006 VW Passat Sedan 3.2lt AXZ, FSI 4motion, another milestone - 398K ... and still going
Do you have a copy of your abs coding from before it was cleared?
That's the easiest way just copy it back.
Can I get the coding from the "old" control module?Originally posted by kamold View PostDo you have a copy of your abs coding from before it was cleared?
Sent from my SM-G960F using Tapatalk2006 VW Passat Sedan 3.2lt AXZ, FSI 4motion, another milestone - 398K ... and still going
No, it's your ABS module coding which was cleared by replacing the EPB module that's the problem. Always always always take AND save a full autoscan before changing anything from a hardware or coding perspective.
If you don't have an old autoscan you might need to do a bit of trial and error to find the correct ABS coding. Luckily it's not an MK60EC1 which has a much more complicated coding scheme.
If you don't have a copy of your original ABS coding try searching online for one from a similarly equipped car.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
