It won't have the correct ratios. Yes it's possible to put a different gearbox in with different ratios, but it will need some custom tuning of the TCU software to get it to work properly.
2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC| 2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|3D colour cluster|Quad LED tail rings|Climatronics upgrade|Dynaudio retrofit|B7 RLine Flat Steering Wheel|3AA CCM|TPMS Direct|B7 Adaptive Cruise with Front Assist|Discover Media retrofit|PLA 2.0|Lane Assist|BCM retrofit|High Beam Assist|DQ500
Yes they are, but the ratios need to be same (ie engine/gearbox combination dictates the gear ratios).
So if you get a gearbox from any other R36 you will be fine.
R36 has shorter ratios than B7 FSI V6 Highline for example even though the driveline is essentially the same - for better 0-100 times.
So you can get a gearbox complete from any R36 and swap it over. Nothing further to be done in terms of calibration, coding etc.
Or you can get a mechatronics from any PQ platform DSG6 car, then flash it with the correct software for R36 and then perform basic settings to learn the clutch and gear characteristics.
Hi Kamold, isn't there a difference with the DQ250 gearbox in the MY10.5 R36 or is this just the mechatronics?
It would be great to know the actual ratios of the gearbox and the final drive? I've never seen this information anywhere.
Biscay Blue MY10.5 Passat R36 Wagon Options: Sunroof, RNS510 Sat Nav, Dynaudio, Power Tailgate, ACC, RVC, BT 9w7, Tint and Factory Towbar. Atlantic Blue MY19.5 Golf GTI Options: Luxury Package and Sound & Style Package.
