VAG-COM communication error, no ABS, rear view camera, parking sensors,etc.
  • VAG-COM communication error, no ABS, rear view camera, parking sensors,etc.
    I've recently had my rear view camera no longer working, the rear electric boot not opening properly, and today a lot of dahsboard lights coming on, eg. no abs speed sensors, no parking sensors etc. Am wondering if I can have bad / corroded wiring or a faulty gateway? I tried scanning with VAG-COM, but half the time it says "Unable to communicate". If I try again, half of the time it works. I got halfway through the auto-scan after trying a few times. I also managed to save each error manually by retrying.
    Any ideas?
    [shortened]
    PHP Code:
    VCDS Version 19.6.2.0 (x64)
    Data version: 20190930 DS308.0
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4C 4F 52 53
              56 61 62 6C 6D 72 77
    VIN: WVWZZZ3CZDE0XXXXX   Mileage: 220840km-137223miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    33-Flux Capacitor -- Status: Malfunction 0010
    37-Navigation -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    6C-Back-up Cam. -- Status: Cannot be reached 1100
    Address 01: Engine (CDA)       Labels:. 06J-907-115-CDA.clb
       Part No SW: 06J 906 027 DE    HW: 06J 907 309 B
       Component: MED17.5.2        05 5359
       Revision: PAH04---    Serial number: VWZCZ000000000
       Coding: 0404000C24070160
       Shop #: WSC 40139 959 131616
       VCID: 71C70889681165C758-8025
    1 Fault Found:
    053271 - Please Check Fault Codes in Control Module for ABS Brakes
                   U1017 - 015 -
                 Freeze Frame:
                        Fault Status: 01101111
                        Fault Priority: 0
                        Fault Frequency: 2
                        Reset counter: 255
                        Mileage: 220785 km
                        Time Indication: 0
                        Date: 2015.03.12
                        Time: 15:06:04
                 Freeze Frame:
                        RPM: 1538 /min
                        Load: 23.9 %
                        Speed: 70.0 km/h
                        Temperature: 97.0∞C
                        Temperature: 42.0∞C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 13.081 V
    Readiness: 0000 0000
    Address 02: Auto Trans        Labels: 0AM-927-769.clb
       Part No SW: 0AM 300 058 Q    HW: 0AM 927 769 D
       Component: GSG DSG AG7     431 6563
       Revision: 00043014    Serial number: CU501511237286
       Coding: 0000020
       Shop #: WSC 01049 002 1048576
       VCID: 3FA39EB16EC5C3B79E-806B
    1 Fault Found:
    006279 - Wheel-Speed Signal from ABS Control Module
                   P1887 - 000 - Implausible Signal
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 0
                        Fault Frequency: 9
                        Reset counter: 10
                        Mileage: 220785 km
                        Time Indication: 0
                        Date: 2015.03.12
                        Time: 15:06:04
    Address 03: ABS Brakes        Labels: 3AA-614-109.clb
       Part No SW: 3AA 614 109 BK    HW: 3AA 614 109 BK
       Component: J104   C2 450M VDF5 0024
       Revision: --H07---    Serial number: 00000005930578
       Coding: 0001914
       Shop #: WSC 05311 000 00000
       VCID: 77D3369106753BF796-8023
    2 Faults Found:
    00290 - ABS Wheel Speed Sensor; Rear Left (G46)
                004 - No Signal/Communication - Intermittent
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 1
                        Fault Frequency: 5
                        Reset counter: 245
                        Mileage: 220785 km
                        Time Indication: 0
                        Date: 2015.03.12
                        Time: 15:06:04
                 Freeze Frame:
                        Speed: 68.0 km/h
                        Hex Value: 0x0001
                        Bin. Bits: 00000000 00000000
                        Voltage: 13.00 V
                        Bin. Bits: 00011111
                        Count: 18
                        Hex Value: 0x0000
    01325 - Control Module for Tire Pressure Monitoring (J502)
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 3
                        Fault Frequency: 9
                        Reset counter: 245
                        Mileage: 220785 km
                        Time Indication: 0
                        Date: 2015.03.12
                        Time: 15:06:14
                 Freeze Frame:
                        Speed: 68.0 km/h
                        Hex Value: 0x0000
                        Voltage: 13.00 V
                        Bin. Bits: 00011111
                        Count: 191
                        Hex Value: 0x0000
    Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
       Part No SW: 3AA 937 087 F    HW: 3AA 937 087 F
       Component: BCM PQ47 M    421 0465
       Revision: BA421001
       Coding: 0008000000000000009802805400006403510088426D8D60648046200041
       VCID: 3D5FE4B9A4C9D1A78C-8069
       Subsystem 1 - Part No: 3AC 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 21061  26  0612
       Coding: 00B795
       Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
       Component: RLS 260612 05  54  0403
       Coding: 0230ED
    1 Fault Found:
    02739 - Bulb for Tail/Brake Light; Right
                010 - Open or Short to Plus - Intermittent
                 Freeze Frame:
                        Fault Status: 00101010
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 10
                        Mileage: 220530 km
                        Time Indication: 0
                        Date: 2015.03.03
                        Time: 00:40:55
                 Freeze Frame:
                            Term 15 Off
                        Voltage: 12.30 V
                            OFF
                            ON
                            OFF
                            OFF
                            OFF
    Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
       Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0025
       Revision: --------    Serial number: 56261216601722
       Coding: 349106
       Shop #: WSC 99999 1023 2097151
       ASAM Dataset: EV_EPHVA2C000000000 002008
       ROD: EV_EPHVA2C000000000.rod
       VCID: 44A9915DCF23A06FC3-8011
    1 Fault Found:
    13637396 - Databus
              U1123 00 [009] - Received Error Message
              [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
              Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 245
                        Mileage: 220785 km
                        Date: 2020.10.19
                        Time: 15:06:03
       Coding: 0000020
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 9
                        Reset counter: 10
                        Mileage: 220785 km
                        Time Indication: 0
                        Date: 2015.03.12
                        Time: 15:06:04
       Coding: 0001914
    2 Faults Found:
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 5
                        Reset counter: 245
                        Mileage: 220785 km
                        Time Indication: 0
                        Date: 2015.03.12
                        Time: 15:06:04
                 Freeze Frame:
                        Speed: 68.0 km/h
                        Hex Value: 0x0001
                        Voltage: 13.00 V
                        Bin. Bits: 00011111
                        Count: 18
                        Hex Value: 0x0000
    Cannot be reached
    Unable to communicate with address 09. Are you sure the doors are unlocked?
    132TSI Tiguan Allspace
    Sounds like what happens when your battery is well on the way out
      Hmm, didn't think about that. I'll put a charger on it overnight to see if it improves things.
      The rear view camera can drop out if the cabling is bad though?
        Possibly but when my battery started dieing I got a dash full of lights and faults and things didnt work and a new battery fixed it but had to go to dealer to get faults cleared
        It still started the TDI but wouldnt run the electrics
          This is absolutely the battery. I have just been through this on my daughter's A1
          Chassis Type: 8X-AU21 (8U0)
          Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 55 5F 62 72
          VIN: WAUZZZ8X7HB021217 Mileage: 59870km-37201miles
          04-Steering Angle -- Status: OK 0000
          08-Auto HVAC -- Status: Malfunction 0010
          15-Airbags -- Status: OK 0000
          16-Steering wheel -- Status: Malfunction 0010
          17-Instruments -- Status: OK 0000
          25-Immobilizer -- Status: OK 0000
          42-Door Elect, Driver -- Status: OK 0000
          46-Central Conv. -- Status: OK 0000
          52-Door Elect, Pass. -- Status: OK 0000
          55-Headlight Range -- Status: OK 0000
          5F-Information Electr. -- Status: Malfunction 0010
          62-Door, Rear Left -- Status: OK 0000
          72-Door, Rear Right -- Status: OK 0000
          Sad to say, but a charge will not fix this, it may help in the very very short term, but its likely a replacement will be required. ... Unless it somehow is not getting properly changed when driving. Incidentally, that was actually the main cause for the A1. A mostly dead battery (30% life left) and an issue with module 08 HVAC caused a drain on the battery at all times. The charging could simply not keep up with the continuous drain. Ended up with a new battery and a new HVAC module
            I did a charge overnight, and I managed to clear most errors. Still has some communication errors, so I agree I probably need a new battery. The rear view camera still has no communication though, so I believe it's either a gateway or cabling issue. The charger showed 13v this morning, but I believe a good battery should show more than that when charged?
