The front strut upper mounting and thrust bearing is starting to make clunking noises and will need replacing sometime in the months ahead. Before I use OEM parts, has anyone upgraded to an aftermarket adjustable strut top mounts?
Adjustable strut top mounts?
2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
