Trying to get ACC "Follow to Stop" working...
  • #31
    Originally posted by passiw View Post
    Can you provide more info about said MED17.5.5?
    03C 907 309 E with fw 03C906016GC.
    Found fts confirmation on drive2 for passat B7 and ABS TRW 450M. But its need to be flashed modified firmware to accept ACC coding.
    • #32
      Originally posted by skypiece View Post
      Pascal, did you fix basic ACC on 7n radar?
      FtS worked with 3aa radar?
      My 7N0 radar has the SWaP code for ACC+FTS, thats why i cant test it with basic ACC (changing the SWaP would be too much of a hustle).
      No, with 3AA radar the ACC also stops working the moment i active FTS; and leads to the same fault in engine ecu as the 7N0 did: "Check coding/variants of modules in drivetrain CAN"
      Would you mind sharing the link?
