B6 Projector Upgrade
  • B6 Projector Upgrade
    So my headlights got so bad it was dangerous to drive at night.
    I'd already replaced the stock D1S with new genuine Philips Xtreme Vision so I knew it wasn't the bulbs.
    After some research I discovered that the Valeo projectors inside the headlights are known for burning out at the back, causing light output to drop.
    I bought a set of lightly damaged headlights from a wreck and some plastic welding tools to repair the broken tabs.
Name:	headlight repair tab.jpg
    Bought a set of Aharon Optimus NT projectors for Right Hand Drive (also known as Left Hand Traffic) from Retrofit lab:
    Aharon Optimus NT - Bi-xenon projectors Hella design
    Cut the headlights open with a dremel in order to access the projector assemblies within:
Name:	headlight open 1.jpg
    Needed new brackets to mount the new projectors as they are slightly fatter and deeper:
    Sealed up the headlights with plastic weld staples and Sikaflex 227:
Name:	headlight sealed.jpg
    Original low beam:
    Upgraded low beam:
    Cutoff:
    Original High beam:
    Upgraded high beam:
    Inner shrouds:
    TAOCHIS Car Styling Shrouds Mask for 3.0 inch HELLA 3R G5 Koito Q5 Bi Xenon Projector Lens Retrofit Head Light Volkswagen Tiguan on AliExpress
    Brackets:
    TAOCHIS Adapter frame Head light for VW Volkswagen Magotan Adaptive Frontlighting System AFS Hella 3R G5 Projector lens-in Car Light Accessories from Automobiles & Motorcycles on AliExpress
    I bet that was a satisfying result. BTW check the time stamp on your edit 03:12 PM
      Yeah super satisfied with the result. I really appreciate being able to see where I'm going in the dark...
      Not sure I understand the edit comment?
        Well done. Your ability to do upgrades never ceases to amaze me. I want to be around when you eventually sell your car!
        2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
        Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
          Never selling it. Just upgrading.
          Actually got it out in the dark tonight and it's sooooo much better.
          Looking forward to a proper night drive in the country now.
            A little darker
              Shutters open for some high beaming
                That’s a fantastic upgrade!
                Do the new lights come with the shutter motor? Mine is faulty on one light.
                  Yes the projectors have the shutter motors in them.
                    nice work - as always
                    that is a huge difference there.
                      Nice job Kamold! This mod made a huge difference, the original lights seem pretty weak in comparison.
                        i think you need to show their performance in a real life situation (city enviroment and low light, road trip, rural) to really get the point across how much of a visual upgrade this is!
                          It's always hard to see in a few pics.
                          You're right in practice the effect is really fantastic.
                          I don't have a GoPro or similar otherwise I'd try and take a video.
                            Nice job, but a lot of work for mere mortals. Did you consider a plug and play replacement with an LED aftermarket set of headlamps from our Ali friends like these?
                            Online Shop Head Lamp For Car VW Passat B7 2012-2016 Magotan Headlights Fog Lights Daytime Running Lights DRL H7 LED Bi Xenon Bulb Accessory | Aliexpress Mobile
                              Led has less light output than hid.
                              Also B7 headlight assemblies don't fit b6
