Guys:
Anybody can shed some light as to what's happening with these error codes and where exactly is the B2 S1 bank situated. Thanks in advance. The error codes are below:
oxygen lambda sensor signals swapped
p0040 B1 S1 / B2-s1 intermittent
freeze frame:
rpm: 624
load: 21.6%
speed: 0.0 km
temp: 73 C
temp: 35.0 C
absolute pres: 1000.0 mbar
volatge: 13.970 V
fuel trim Bank 2
P0174 001 - system too lean
freeze frame:
rpm:1340
load: 65.1%
speed: 55km/h
fault frequency: 2
temp: 74.0 C
temp: 16.0 C
absolute pres: 1010.0 mbar
voltage: 13.097 V
Oxygen Lambda Sensor B2 S1
P2197 signal too low (lean)
freeze frame:
rpm: 1620
load: 54.9%
speed: 75km/h
fault frequency: 1
temp: 80.0 C
temp: 9 C
absolute press: 1010.0 mbar
voltage: 13.843 V
Post catalyst lambda sensor correction
p2099 too rich - intermittent
freeze frame:
rpm: 2044
load: 43.5%
spped: 59 km/h
fault priority: 0
fault frequency: 1
temp; 84 C
temp: 13.0 C
voltage: 13.970 V
test mode 07: pending emission related fault codes
address 7EB: 1 fault found
P2234 - oxygen lambda sensor B2 S1: signal shorted to heater circuit
freeze frame:
rpm: 624
load: 21.6%
speed: 0.0 km
temp: 73 C
temp: 35.0 C
volatge: 13.970 V
fuel trim Bank 2
freeze frame:
rpm:1340
load: 65.1%
speed: 55km/h
fault frequency: 2
temp: 74.0 C
temp: 16.0 C
voltage: 13.097 V
freeze frame:
rpm: 1620
load: 54.9%
speed: 75km/h
fault frequency: 1
temp: 80.0 C
temp: 9 C
voltage: 13.843 V
freeze frame:
rpm: 2044
load: 43.5%
spped: 59 km/h
fault priority: 0
fault frequency: 1
temp; 84 C
temp: 13.0 C
voltage: 13.970 V
 I'm hoping though this was as a result of the upstream B2 S1 failing but I haven't scanned the car for errors since the AN & AM replacement.
