Originally posted by IanPGonzaga
View Post
R36 PCV Valve Replacement
Hunting revs at idle is the classic symptom.
Sent from my SM-G960F using Tapatalk2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
bad fuel trims will also be apparent, due to the unmetered air.
Yes if you check with diagnostics will be evident.Originally posted by h100vw View Postbad fuel trims will also be apparent, due to the unmetered air.
When I had a leank due to the upper intake not sitting flush the trims were way out.
