The passat's remote fob has a plastic key that you can pull out. According to the car manual, you can use this plastic manual key to lock and open the driver's side door. I remembered I tested it okay when I just bought my new 2008 TDI back then.
Never tried it again until a couple of days ago as I want to use this feature later that day. However, I was only able to lock the doors with the manual key but I can't open the door with it! When I turned the key, the headlights flashed once but the door still locked. Lucky I tried it first otherwise I would have locked the remote fob inside the car!
Any setting changes that may have stopped it from opening?
