I have a 2007 3.2L V6 Passat. Last month I had a major engine repair done at a dealer and they fitted a new sump plug (N90 813 202). I did an oil change at the weekend and found this new sump plug is different to the one I'd always had.
The original sump plug was aluminium with an aluminium captive washer and 18mm head. This one is steel with a steel washer and a 19mm head.
When I checked with service and spare parts at this dealer, they only supply steel sump plugs now. Setting aside any potential issues of two alloy parts corroding together, I'm not sure it makes sense for the plug to be made of a stronger material than the sump itself. I'd rather the plug be the sacrificial component!
Is anyone aware if VW have made this change? And for what reason?
