So - for reference:
2007 MY08 Passat 125TDI, 110,000km, full service history.
I had huge problems with my Passat today and it left me in a very dangerous situation. School holidays, car packed, heading to the Sunshine Coast from Gladstone.
Bruce Highway southbound between Turkey Beach and Bororen, QLD, 105km/h set on cruise control, AC on, lights on, stereo on, wipers on as there was a little rain about.
Out of nowhere the engine warning light illuminated and the MFD read "Engine Fault: Workshop!" The car then disengaged it's cruise control and lost all power, grinding to a halt and stalling on a black spot on the Highway where there is next to no room for the B-Doubles to sneak past and very small areas to pull of in.
So, stuck in the middle of the road over the crest of a hill waiting for a truck to come from behind at 110km/h I cycled the ignition and the car started and drove another 150m or so and again, the light illuminated and whooshka, no power, pull over... this time it decided to konk out close to an area with some grass thankfully.
So I call up VW Roadside Assist, they send someone out. I am waiting in the car and attempt to start it a few times, just turning the engine over for 3 or so seconds to no avail. RACQ man arrives... he does the usual stuff that I had already done, checks oil, this that and then says "well I can't do more for you here, will it start/run?" I explained to him what happened above, and I cranked the engine and it turns over and fires up perfectly!
Next thing you know we've headed back to Gladstone and the car runs the 45 minutes perfectly like nothing had even happened!
A little background: 4 weeks ago, on the odd first start of the day I'd cycle the ignition and the car would not start on the first try and threw a fault code / message. After cycling the ignition the second time it started up straight away. This has happened over the last 4 weeks only a handful of times and for all intensive purposes the car has ran fine throughout this period. We have had a fair amount of rain in the past few days.
So... my list of possibilities?
1. Rail pressure sensor?
2. Crank angle sensor?
3. Injector?
4. Fuel pump?
5. Other sensor?
6. Bad diesel?
Closest VW dealership is Rockhampton, 115km North of Gladstone on a very busy stretch.
Any thoughts, comments or ideas are appreciated.
Anthony.
3. Injector?
4. Fuel pump?
5. Other sensor?
6. Bad diesel?
Anthony.
