There are some good answers here, and what I can add without breaking forum rules, is that the answer is generally dependant on what the company in question is selling. The legitimate answer to tuning any engine whether it be VW or Lamborghini is to custom tailor it on the dyno for the optimum torque for the ignition timing and air fuel ratio that it will support on the fuel it is being run on
Dyno Tuning vs ecu remap / chip tuning
Thats the Point Swallowtail..
Thats the whole point of the chips, they bring the overly conservative factory mappings back towards the ideal world figure of 14.7.
The chips lean the cars out to achieve significant performance / economy improvements at minimal risk.
The 1.8T engine has to be one of the most tuned engines in history (behind the 2.0T and the WRX)! All the major chips have been tweaked and retweaked to provide the max possible enhancement over the factory settings, while maintaining a very safe margin above those catastrophic words like pinging, detonation, blowby, and blown turbos.
Go for the chip - you will bring your 1.8T up to the performance level of a factory 2.0T no probs!RIP!
2007 Passat 3.2 4Motion Black Sedan | 19"s | AVC-9000 | Audi A3 Sportback 2.0TFSIQ
3Putt - as already stated on more than one occasion for modern turbo engines 14.7 is not ideal. Go and try it...Originally posted by 3Putt View PostThats the whole point of the chips, they bring the overly conservative factory mappings back towards the ideal world figure of 14.7.
been there done that... the most you want with a modern turbo is 12s or 13s. Tuners go pale and very quickly get off the throttle doing dyno runs if they see 14s.
I already commented that my tune took my mazda from 10:1 to 12/13:1, so I am fully aware of what "the point" is...
A chip or a flash (or is that what you mean by "chip"?), or whatever poison you choose, can both (dependent on the car, the technician and the device) get you similar results. With modern ECUs however a "tune" can be very hard to achieve anything with, as they are so locked down. It usually takes either a reflash or a piggyback chip to overcome the factory ECU's built-in parameters to any noticeable extent.
E.g for the Mazda 2.3T motor that I have come from I gained about 20% atw with a piggyback. Others got similar results from a flash. There is quite simply nothing to tune without either one of those paths being taken.
I'm not sure what you are trying to say with your post that hasn't already been said? Or am I missing something?
Originally posted by Martin Donnon View PostThere are some good answers here, and what I can add without breaking forum rules, is that the answer is generally dependant on what the company in question is selling. The legitimate answer to tuning any engine whether it be VW or Lamborghini is to custom tailor it on the dyno for the optimum torque for the ignition timing and air fuel ratio that it will support on the fuel it is being run on
Spot on!! is this the real MD that used to write for Ben Ellis??
Back to topic: most tuners will tune for best performance WITH the current fuel that is in the car as it is a factor in the tuning process, but a rich tune=safer tune to compensate for lower RON fuel to prevent engine knocking.
Originally posted by Swallowtail View Post3Putt - as already stated on more than one occasion for modern turbo engines 14.7 is not ideal. Go and try it...
you are not missing anything dude, u are just on a different level.
Infact, we did run a Motec in our GTR a few years back and we were able to squeezd out to a near perfect 14 for almost every 100 revs on C10. But as soon an we ran Optimax it was history......all comes down to hareware and tuner.
swallowtail, i have been told by my bmw specialist he has used tuning boxes with really good results. (mainly for turbo diesels eg x5 3.od engine) which can be plugged in and unplugged at will ( ie when you send the car back for service) and give performance and economy improvements - or are these inferior to the proper flash?Originally posted by Swallowtail View Post3P
i gather from the above comments you would be sceptical?had a passat tdi. now mb c class.
Not at all - I had a piggyback on my Mazda with brilliant results. Handy to be able to remove at will...Originally posted by tryingavw View Postswallowtail, i have been told by my bmw specialist he has used tuning boxes with really good results. (mainly for turbo diesels eg x5 3.od engine) which can be plugged in and unplugged at will ( ie when you send the car back for service) and give performance and economy improvements - or are these inferior to the proper flash?
My comment was that you either need one of those OR a flash - there is usually very little that you can do to a modern ECU without one of them.
thanks for the feedbackOriginally posted by Swallowtail View PostNot at all - I had a piggyback on my Mazda with brilliant results. Handy to be able to remove at will...
- as a matter of interest was it a turbo? and in what respect did you get the improvements
Originally posted by Swallowtail View PostOh yes, it was feral with the extra power. With awd grip planting an estimated 230+ KW and 430NM torque 1st gear was breakneck stuff, but the real pickup was just in sheer tractability in-gear. It was well worth it.
how about economy with regular driving
? or couldnt you resist planting the foot
Made no difference to economy actually. The 2.3T mazda engine is not particularly economical at the best of times, but I averaged 11 - 12 pretty consistently both before and after. I think maybe the leaned out tune maybe offset the foot-planting bit! LOL...Originally posted by tryingavw View Posthow about economy with regular driving
So are you going to do the same thing with R36? How would you compare the standard R36 with the MPS upgraded?Originally posted by Swallowtail View PostOh yes, it was feral with the extra power. With awd grip planting an estimated 230+ KW and 430NM torque 1st gear was breakneck stuff, but the real pickup was just in sheer tractability in-gear. It was well worth it.Gone...........R36 Icelandic Gray Wagon
Specialising in off-topic discussion
