There are some good answers here, and what I can add without breaking forum rules, is that the answer is generally dependant on what the company in question is selling. The legitimate answer to tuning any engine whether it be VW or Lamborghini is to custom tailor it on the dyno for the optimum torque for the ignition timing and air fuel ratio that it will support on the fuel it is being run on
 been there done that... the most you want with a modern turbo is 12s or 13s. Tuners go pale and very quickly get off the throttle doing dyno runs if they see 14s.
 been there done that... the most you want with a modern turbo is 12s or 13s. Tuners go pale and very quickly get off the throttle doing dyno runs if they see 14s.  My comment was that you either need one of those OR a flash - there is usually very little that you can do to a modern ECU without one of them.
						 ?  or couldnt you resist planting the foot
