1980 B1 Passat Project
  • From Lynx!
    Lynx Corporation
    They still make them believe it or not! I think I used the one that was in the kit below and modified it a bit by bending it and adding an extra tapped hole for the cable to bolt to.
    I recommend using a nylock on the threaded part of the throttle cable. Anything else winds off.
    Product Details
    Their website isn't the greatest but they're very helpful over the phone and will post the bits out.
    They're a good source of the ram-flow filters and parts if you're looking for those too.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    • Hi Pete, thanks. I have this kit, but I thought perhaps I had a different bracket. Did you find the kit well made? I needed to file the half moon shaft hole to fit neatly and the holes on the swivel arms as well. Meccano is better made?
      • I don't recall mine being too bad but there's always some fettling with these things.
        Use plenty of loctite on all the nuts and bolts!
        7? MK1 Caddy
        12 Amarok
        • Frank and his great, great, great, great, great grand daughter Audrey (B1 vs B8 )
          7? MK1 Caddy
          12 Amarok
