Purple Xenon Headlight
I had no idea, I thought it just looks weird that it was colour temperature change, not a complete failureOriginally posted by gldgti View Postwhat could be more serious?
I would guess at the bulb failing if the colour temp is changing.
I'm going to look for Philips Xtreme-Vision or Osram Night Breaker unlimited to replace them both.
Any idea what the OEM colour temperature is?
Thanks,
Vexed
You should replace both at once. And those globes you mentioned are halogens. You want Xenarc or Xenstart, those are the Philips and Osram HID globe brand names.
On the R36 you have to pull the bumper off to replace them, not sure about the CC..2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Originally posted by kamold View PostYou should replace both at once. And those globes you mentioned are halogens. You want Xenarc or Xenstart, those are the Philips and Osram HID globe brand names.
Yes I actually meant this one
XENARC NIGHT BREAKER UNLIMITED | OSRAM
I hope I don't need to take the whole bumper off, will give it a try
Thanks again guys, as always, you have been very helpful.Last edited by Vexed; 06-06-2015, 02:38 PM.
Ah my mistake didn't realise they use the same branding on the HIDs.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
I've had a look at the back of my headlights, definitely appears as if you need to remove the bumper then remove the headlight housing. The access hole to where the HID globe is tucked inside the fender. Have you googled for a walk through?
Yeah there are ETKA diagrams floating around. It's not too bad once you've figured it out but still annoying. I had trouble with some screws in the wheel arch, need a long driver.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
I received my headlights today, I believe they are fake although I bought them on Ebay from a seller with 3000+ 100% feedback.
Anyway, been trying to remove the passenger's side lamp with no luck. I would like to compare the current bulb with the new ones.
It looks like I have to press on the clip and pull out, as I can see from the pic. Is that correct?
how about thru the fender wheel well? i removed my liner (but golf r) and saw plenty of access.
Sent from my GT-I9506 using TapatalkMitsubishi Pajero Sport - Super Select 2WD/4WD
MINI Cooper S Clubman - FWD
Today I received the genuine Osram Xenarc bulbs that I ordered from PowerBulbs. Comparing them to the bulbs that I bought from Xenoneurope of eBay, the eBay bulbs are 100% fake. It turns out 90% of HID bulbs sold on eBay are fake.
I recommend against buying HID bulbs from eBay. Pay a bit extra and get them from an authorized Osram or Philips dealer.
Unfortunately for me, I discovered that after my eBay order was shipped.
I took the genuine bulbs to my VW specialist, it took him 15 minutes to install both bulbs LOL
They are brighter than the OEM ones.
Did he need to take the bumper off?2018 BMW 125i M Sport |AlpineWhite|719M JetBlack|BlackLeather |ComfortPackage|Sunroof|WirelessCharging
2010 MY10 R36 Wagon | Biscay Blue | Power Tailgate | RNS510 | MDI | RVC | 51,000 km |Garage Open Button | Dead Pedal Mod | OE Fit DRL | VCDS | Sprint Booster | H&R Rear Sway Bar | Alcantara Steering Wheel | Dual Reverse Light | 19" Bentley Wheels (BBS Forged Split) | Michelin PS 4S
2005 MY05 AH Astra HatchBlack | Facelifted SRi Looking | OpeliZed | Whiteline RSB | Eibach ProKit
