Okay,
Has me stumped!!! EPB works - you can always hear it close/open when you press the button!
Now, I've checked this for several weeks in a row now to be 100% sure, and without exception, the EPB amber warning light will only come on when I make a left-hand turn!!!??? It doesn't always come on every single time I turn left, but when it does come on it is without exception when I'm turning left (not going straight ahead, reversing, turning right or sitting still with engine on)!
I clear the fault with the Foxwell scanner only to have it appear later again at some point (and always on a left-hand turn)!
The fault on the Foxwell scanner is always: 02433 Supply Voltage for Right Parking Brake Motor (V283) - sporadic 007 - Short to Ground.
Vehicle: 2009 Passat CC 2.0TDI (CBBB engine).
Has anyone else had this happen? Any suggestions?
