Hello all
I recently replaced timing chains on my VR6 CC. While the motor was out I decided to do lower control arm bushes and front pads and rotors. I did not crake the brake nipples when I changed dics and pads, I simply pushed the pistons back.
My issue now is my brake response seems somewhat poor compared to the prevous set.
Is there a way of bringing the brake pedal back up (soft push immediate response)? Can VCDS boost brake pressure?
