Going for as many as they can get out of it, I have seen them get 360 kw at the wheels also seen they got 415 kw on one manual golf, So told them I want what ever they can get out of it I want to run into the 10's
1 of 2
2 of 2
Stage 1 vs stage 2 - cost, gains
Originally posted by BO11OS View PostNo standard engine with with all bolt on's.
i wouldnt be spending any money on upgraded clutch packs or whatever u dont need it unless u burn urs which u probably wont
Source urself a pair of 2nd hand bigger brakes off a porsche or audi
Originally posted by amunra View Postthe ea888 is capable of alot of power 600+ HP if your tuner limits the torque not to blow the engine... if u want big torque which might be needed after u do ur stage 3 ur gonna need to build ur engine and clutchpacks then..
Interesting... 600HP+ (447kW+) would be impressive.
The Stage 3 bolt-on pathway I'm following reliably does 365kW (590Nm) - apparently it has a higher ceiling, but needs some engine strengthening to avoid breaking things: Stage 3 Turbo Kit for Golf R, Audi S3, Cupra, GTI | RacingLine
It "requires" a new clutch-pack (rated to 700Nm), but I was told to do that upgrade if/when the OEM clutches wears.
Just had another look at they tested a 2014 Golf R and got 0-100 in 2.9s and 400m in 10.92s - understanding that an Arteon is a heavier beast... makes me want to explore weight saving options ;-P
2018 Arteon R-Line - Black, Sunroof, Dynaudio, 20" Wheels, RacingLine: Stage 2 ECU+DSG|380mm BBK|Intercooler+Hoses|Oil Cooler|R600 Intake|Adjustable Front Droplinks|Dogbone Insert|Subframe Brace+Alignment Kit|Propshaft Alignment Kit, Milltek: Zirotec Downpipe, Harding: Front+Rear Sway Bars|Rear Droplinks, Other: OSRAM Dynamic Indicators, EvcX Throttle Controller, 034 (RED) Coil Packs, Various Carbon Bits
Originally posted by nermal View PostInteresting... 600HP+ (447kW+) would be impressive.
theres enough 550 - 600 - 700hp ea888s showing it can be done on stock internals and 6speed gearboxes. if u have the 7 speed DSG it should be stronger than the 6 speed and only need to upgrade the clutches as u burn them or are doing many launches / drag meets.
Did you see if these power number are on 98 pump fuel or E85?
The tuner I am using is getting the numbers + you quoted but uses his own flex fuel setup. They just re wrote the GTI world record with a 9.9 @ 119, they also ran a 10.07 @140 HE isn't saying how much power it has only that it's over 400kw.
[ATTACH=CONFIG]54130[/ATTACH]
Originally posted by BO11OS View PostDid you see if these power number are on 98 pump fuel or E85?
The tuner I am using is getting the numbers + you quoted but uses his own flex fuel setup. They just re wrote the GTI world record with a 9.9 @ 119, they also ran a 10.07 @140 HE isn't saying how much power it has only that it's over 400kw.2018 Arteon R-Line - Black, Sunroof, Dynaudio, 20" Wheels, RacingLine: Stage 2 ECU+DSG|380mm BBK|Intercooler+Hoses|Oil Cooler|R600 Intake|Adjustable Front Droplinks|Dogbone Insert|Subframe Brace+Alignment Kit|Propshaft Alignment Kit, Milltek: Zirotec Downpipe, Harding: Front+Rear Sway Bars|Rear Droplinks, Other: OSRAM Dynamic Indicators, EvcX Throttle Controller, 034 (RED) Coil Packs, Various Carbon Bits
Hi nermal, I am sceptical as from what I have seen to achieve those sort of number you'd need to be running on E85 not a stock engine with a high flow turbo.
The bolt on's I am getting are a lot more than that & I would expect to see between 350 to 380 kw at the wheels. But that's running on E85.
Originally posted by BO11OS View PostHi nermal, I am sceptical as from what I have seen to achieve those sort of number you'd need to be running on E85 not a stock engine with a high flow turbo.
That is a Hybrid Turbo exchange and the Stage 3 also requires a lot of other parts to achieve those figures - R600 intake, pipes/hoses/elbows, intercooler, performance catted downpipe & exhaust, upgraded fuel pump etc, plus recommended 700Nm clutch upgrade, big brakes etc.
You can easily get to the $20-25K mark once you add all the hardware and ECU + DSG tune.2018 Arteon R-Line - Black, Sunroof, Dynaudio, 20" Wheels, RacingLine: Stage 2 ECU+DSG|380mm BBK|Intercooler+Hoses|Oil Cooler|R600 Intake|Adjustable Front Droplinks|Dogbone Insert|Subframe Brace+Alignment Kit|Propshaft Alignment Kit, Milltek: Zirotec Downpipe, Harding: Front+Rear Sway Bars|Rear Droplinks, Other: OSRAM Dynamic Indicators, EvcX Throttle Controller, 034 (RED) Coil Packs, Various Carbon Bits
Looks like Racingline worked with VW Australia to build a "track ready", "Stage 3" Arteon with 360kW, 600Nm and 0-100km/h in 3.9 seconds (?"on an uphill straight"..."consistently"?)
I remember reading about this one, but didn't realize it was Racingline: VOLKSWAGEN CHOOSES RACINGLINELast edited by nermal; 06-06-2022, 08:07 PM.2018 Arteon R-Line - Black, Sunroof, Dynaudio, 20" Wheels, RacingLine: Stage 2 ECU+DSG|380mm BBK|Intercooler+Hoses|Oil Cooler|R600 Intake|Adjustable Front Droplinks|Dogbone Insert|Subframe Brace+Alignment Kit|Propshaft Alignment Kit, Milltek: Zirotec Downpipe, Harding: Front+Rear Sway Bars|Rear Droplinks, Other: OSRAM Dynamic Indicators, EvcX Throttle Controller, 034 (RED) Coil Packs, Various Carbon Bits
Originally posted by BO11OS View PostYes you can, adds up very quick.
I still think u can get stage 3 fun for 10 - 15k max
Originally posted by amunra View Postadds up quick if your overspending on parts u dont really need for the build to go fast. its sort of overkill to protect the tuner / builder and ur the one paying for it..
Sure, everything can be done cheaper. Keen for you to get a Stage 3 for 10k fully installed and let us know how it goes after a year.
I spent a lot of years in the JDM tuning scene and people think they are clever zip tying front mounted ebay intercoolers with pvc piping, but it always catches up with them.
Originally posted by Vedi View PostIf you read the room, people are not interested putting the cheapest possible no-name parts in their cars.
Test Slow
