Tow Bar an issue for Touareg?
  • Tow Bar an issue for Touareg?
    Hi readers/members. I have just read a letter in Victoria's Royalauto magazine that suggests VW have a problem supplying a tow bar that adequately supports the tow capabilities of the vehicle. Can anyone shed more light on this issue for me?
    On the new Touareg, there were supply issues regarding the wiring kits, as the orinal kit made for them didn't work with some functions on the cars. This has since been rectified. There was another concern, where people were fitting the previous model's towbar. While it does in fact bolt up, it is of the incoreect capacity.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
      If you want a towbar for Treg, check out Hayman Reese towbar which is rated at 3500kg/350kg and costs about half that of the VW Treg towbar ... and the hitch receiver faces horizontally unlike the current VW towbar which faces vertically (such that you cannot fit a hitch-mounted bike rack)
      Regards,
      Golf 103TDI MY09, Touareg 180TDI 4XMotion MY12
        I think you will find a towbar with 350kg downball is incorrect as the vehicle is rated for max downball load of 280kg. Thats the reason the towbar of the old 7L6 model cannot be used on the new 7P Touareg.
        Boris
          Correct.
          Hayman Reese have a habit of doing their own thing with towbars, regardless of whether they're ADR-compliant or not.
          '01 Beetle 2.0
            I Do not suggest using after market. If you have most options like auto rear tailgate and adaptive cruise all these electrics are incorporated and coded specifically to the vehicle this can only be done 100% at Volkswagen during installation.
            Sent from my iPhone using my fingers.
