Hi , My 2009 Tiguan 147 TSI recently developed a severe engine missfire which required the car to be towed to a VW dealer . Initial inspection indicated no compression on number 4 cylinder . Once the head was removed two bent valves were found . So far no real explanation has been given as to what was the root cause of the valves bending but it wasn`t expected to be a timing chain /tensioner issue as no other valves were damaged.
The fix is a replacement head with a job quote of approximately $6500.
An application was made to VWA for goodwill but was rejected outright.
Given that the car is around 6 and 1/2 years old with approx 121000 on the clock and has full VW service history i feel somewhat let down by VWA`s response .
