Changing low beam bulbso
  • Changing low beam bulbso
    I bought some Narva 120% plus bulbs for the low beam. Drivers side was very easy. But the passengers Side was a pain. I ended up removing the headlight Support bracket. Along the top of the headlights .
    Some of you might have small hands but to get your hand down between the fuse box and the low beam was very painful I did manage to remove it but no way could I reinstall the Fitting I've still got the marks on my wrist. To prove. How tight it was.
    You sure that's how you got a swelling in your wrist?
    Dingah
      well i tried both hands and neither could screw it in
        Hopefully it's like the pre-FL Tiguan, where you can pull the whole headlight out quite easily.
        '07 Transporter 1.9 TDI
        '01 Beetle 2.0
          I got the L/H. In but only after removing the Metal bracket. That holds the top of the headlight in place. The R/H. Was a piece of cake Hopefully. One doesn't have to change the L/H. Again. ?
