Cheers - will mention it when I pick the car up.
Tiguan 125 TSI Manual - Weird Hesitation around 2500 - 3000 RPM
Hi All, just an update.
Had the coils replaced just to be sure. No change still jerky idle and hesitation.
I had them check the car again today, went for a drive with mechanic and he did notice the problem. They want to try the PCV valve.
But I do agree, the borascope would be a good idea - anyone got one? I dont want to get charged
Also - I read that thread you posted about the studder/flaps. Sounds familair, but I have a weird idle as well. You can feel the engine shuddering on the steering wheel, but it doesnt always happen, then sometimes its more intense. Even my wife notices it
I'm convinced that VW/Audi/Skoda don't really care about the longevity or service costs of their product beyond the average ownership period for new car buyers and attempt to keep service costs in the first 3 yrs of ownership artificially low by stretchin service periods to a maximum.carandimage The place where Off-Topic is On-Topic
Update -
I manually cleaned the valves. Hesitation is still there although not as abrupt.
Things that have been replaced / cleaned so far.
PCV
Spark plugs
Coil Packs
Intake valves manually cleaned
Not sure what else it could be, maybe just a characteristic of the engine.
I did read on an american forum that the intake runner flappy motor (vacuum driven) can get a bit worn and so doesn't turn the flaps as efficiently when the engine gets older.
If anyone has any further advice / comments please respond.
Wayne
I've got the same issue with hesitation on a 125TSi but I'm running an APR stage 1 tune. Very noticeable in 3rd gear under heavy acceleration. I've had all the usual service things done, plus had it re-flashed and looked at by APR nobody can find the issue. At about 90,000kms I changed the intake manifold because the arm on the side which controlled the flaps kept popping off (some clip broke). This also didn't resolve the issue.
However running stock, I cannot get any hesitation so would be interested to see what resolves this.
